Old 06-01-2014, 10:57 PM   #1
Automatic Hydraulic leveling system
Has anyone out there ever had a automatic hydraulic leveling system installed on a 5th wheel. Our 5th wheel now has front hydraulic legs on it but I would really like to add mid and rear hydraulic legs with the automatic set up system if that's possible.
jabbo is offline   Reply With Quote
Old 06-02-2014, 05:55 AM   #2
When the systems were new 3-4 years ago, quite a few people had them installed. Their stories are on threads here at FRF and on other forums. You would just need the brackets welded on, jacks, lines run, new controller, additional Hydac valves, new touchpad, rear sensor, maybe a new manifold, and possibly a larger fluid tank. Easy.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 06-03-2014, 07:41 AM   #3
Old Enough to Know Better
gasman6674's Avatar
I am lucky enough that my rig is factory prepped for level up (brackets mounted on frame) When I checked into up grading the "Lippert factory auth dealer wants $4000 so I am going to pass for now.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
hydraulic, leveling
