Old 03-01-2016, 12:39 PM   #1
Automatic Leveling
I'm looking at either the Lippert 6 point ground control or the Lippert Level Up. There is only a $400 difference in the price of having them install it. Can anyone give me the pros and cons of the two different systems? I'm putting this on a 2016 Heritage Glen 268RLBHK 42' 5th wheel.
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Dinostop is offline   Reply With Quote
Old 03-01-2016, 01:04 PM   #2
Don't know what the difference is, but I have the Lippert 6 point auto level system on my FR Vengeance toy hauler. The ability to press one button, and have the camper perfectly level, is a godsend. You can also manually control front, left, right, rear if you need to. The digital battery voltage readout gives you a real time look at the battery, rather than the idiot lights.
Ultraboy is offline   Reply With Quote
Old 03-01-2016, 01:05 PM   #3
Which system do you have, hydraulic or electric?
Eastlake, Ohio
Old 03-01-2016, 01:08 PM   #4
Hydraulic. A 12 volt motor runs the hydraulic pump. If your battery is low, it ain't gonna work without a jump or fire up the genny.
Old 03-01-2016, 04:03 PM   #5
Guys, just keep one thing in mind about this system, if you "overextend" any one of the jacks the system will shut down and then you will have to manually bring back the slides and jacks using a drill and 1/4" bit. Always use blocks under the high side. Just say its voice of experience talking. My system is electric over hydraulic.
dkelly is offline   Reply With Quote
Old 03-01-2016, 04:06 PM   #6
Fulltime family RVer
IMO, ditch Lippert and look at the Quadra Bigfoot system. Any time that I can avoid Lippert, I do so.
Old 03-01-2016, 04:07 PM   #7
TURBS's Avatar
That's what's nice about the electric system, just a small 2x6 under each leg. No need to carry around bulky blocking
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-01-2016, 04:26 PM   #8
I only carry 6 10 x 10 x 1 1/4" boards now and only use them when I need to. Especially under front jacks.
Old 03-01-2016, 06:20 PM   #9
2015 Columbus 320RS
2008 2500HD Duramax
Hey Turbs, is there a weight limit on the electric system? I would think hydraulic is going to lift more weight it you have a bigger rig.
MightyMike is offline   Reply With Quote
Old 03-01-2016, 06:30 PM   #10
My 5er only weighs 11,000 dry. I'm thinking electric my be the better choice.
leveling
