01-10-2012, 12:02 AM
Don't forget the extra weight of the gas in the tank. You will be adding 300lbs of gas plus the weight of the tank to the box of your TV.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
01-10-2012, 12:17 AM
The DuraMax flow and go hold 14 gal. and is DOT approved. It has a nozzle for transferring fuel. The cost in Canada is $140 and should be less in the USA. The features are - Holds 53L of gas
- Moulded-in pull handle
- Plastic molded wheels
- Two shut off valves for disconnecting hose
- Includes Flo n' Go fluid transfer gas pump
- Built-in hanger for easy hose storage
- Made from high-density polyethylene
- Ergonomically designed to make transporting fuel easy
- Vented fuel refilling cap
Terry and Janet
2007 Ford F150
01-10-2012, 09:46 AM
Moderator
In North Carolina, the max allowable tank is 55 gallons. After that you must have a CDL with a HAZ MAT endorsement, and placard your truck accordingly, carry a fire extinguisher.......... I know because my neighbor got caught and ticketed with a 100 gallon tank. Guess the officer was having a slow day.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 529 |
| 98 members and 431 guests |
| 4bnabird, Al Fresco, amxpress, Big Vic, billy bob, Biscuit, bowshark, Buffalohunter, campnqueen, Canuck_Doug, Char_n_Kath, chiro, cousin01, dashonthedash, daveinpickerington, davidjb, daw592, DDC, dimurrrw, DonG, donn, duchie, Elidh, Filthy Beast, fonzie, freedom 750, gandr96, Gary0848, gimp425, Gman88, Goomph, gucci, herk7769, heytomgraywolf, Hob, honda1, hoovercab, Huey1946, Hydrothunder, jacksum2, Jeep4Two, JJFerg, Joseph5410, jpetrey, kathomas, KKapa, KRS, lochsa, Lumpty, mack63, Mad4sax, maggiek, mamentt, manvel, milw156, mraynie, mtl roofer, NanaKaren, NeilM108, newby, NO3putt, NorminN.B., ns-sabre, okdrifter, papap, polkatronron, Poppy Bill, railstar, rbrandon, RGH, rickthelen, RickV, RJHuser, RV Guy, Sahgie, Saratoga Camper, Sawdr73, sherdep, sideout1961, skipper194242, snipe, softwarejoe, sprayking, spurge1947, stevem4134, Tee, tfedd, thewren, Tincup13, tinker, Titleguy, TopGobbler, troyt, venturetaz, wbdvt, will4u, wnytaxman, yworrydog |
| Most users ever online was 1,025, Today at 01:04 PM. |
