06-10-2018, 06:33 PM
Awning lights
Hard to find good lights. Lots of junk out there
Got lights from boogy lights. Multi light kit.
Can change to whatever color I want. Also brightness controlled
Install was easy
06-11-2018, 10:47 AM
Install was easy
That's a great looking deck area!
2015 Freedom Express 246 RKS (Sold 2021)
2021 Grand Design Reflection 150 295RL
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2021: Still Not Enough
06-12-2018, 09:26 AM
Install was easy
Attachment 175385Attachment 175386
Do you have a link to where you got them? Mine are a weak excuse with 1/3 out and dim light from the rest.
Found them, thanks
https://www.boogeylights.com/led-lig...SAAEgKjaPD_BwE
06-12-2018, 10:16 AM
I tried those garbage ones that side into the slot. Junk. Used once
06-12-2018, 10:49 AM
Install was easy
We also have a Grey Wolf and our awning LEDs are blue. I hate them. We've never turned them on. Were your original lights also blue? If so how did you remove the old lights and what did you use to stick the new ones up?
Looking at boogy lights the multi-colored LEDs at 16' was $124.99 for the add on. Is that right?
2017 Cherokee Grey Wolf Limited 26BH
06-12-2018, 11:41 AM
The original one I bought just slides into the slot on the awning roller. Was white. Wasn't bright at all. Junk.
Got the muti color so I could use whatever color I want.
I got the optional bluetooth addon as well. Can control the lights with my phone
06-12-2018, 11:45 AM
So you didn't have awning lights before? What did you attach the new ones with?
06-12-2018, 12:01 PM
No just bought the slide in lights. These lights stick on
These are good quality lights.
You can also cut them shorter if you need to. I cut 1 foot off
06-13-2018, 02:33 AM
Those look good. I've been thinking about changing my factor LED awning lights since mine are just bright white that we just leave off most of the time. Could these be slid in the factor clips or do they have to be taped on?
2018 Ford F-450 DRW
2017 Sandpiper 379FLOK
06-13-2018, 08:10 AM
They stick on.
Also you can change the brightness to whatever you want
06-15-2018, 11:33 AM
If u get the bluetooth add on you just download the App
06-15-2018, 11:57 AM
Got mine on E-Bay
Got my RGB strip, RF controller and hand held remote on E-Bay for about $40.00. All the strips are made in China anyway. I did use 3M double sided tape to install even though the strip had sticky tape. My experience is the standard sticky tape is not very good but the 3M tape was cheap. I love my lights and they have been on for 3 years now.
Just saying....
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
06-16-2018, 06:59 AM
The boogey lights, are they a good replace,ent for the factory lights? Do you have to hide or mount any control boxes, or do you just tap into the existing awning light power? Even with the Bluetooth module?
2019 Flagstaff V-Lite 30WFKSV
2021 Chevy Silverado 3500 HD DRW High Country
06-16-2018, 07:30 AM
Mine are factory and set to Blue. Has anyone noticed that the Blue seems to attract about 100X more bugs than any other color ?
06-16-2018, 07:34 AM
I was looking at putting some permanent awning lights up myself, like the Boogie Lights. How do you get the power to them? I haven't looked into it that far yet, is there a power wire or outlet on the power awning already there to add these lights? My trailer does not have any lights on the awning yet, so I would be putting them on for the 1st time. Any help would be appreciated, Thanks
06-16-2018, 08:42 AM
I drilled a hole through to inside and used the same power from the yellow light. Hook the little box up there and your done
