Old 05-14-2012, 04:36 PM   #1
Awning lock
After reading about the horror stories about awnings coming unfurled on the highway and looking at various commercial locks, I decided that I needed to come up with some way to lock the awning. This serves dual purposes as it prevents the awning from unrolling in case something happens and the motor releases and it prevents any accidental signal from the remote control that was an ingenious modification shared by f1100turbo. With this lock, there is no need for an awning electical shutoff as the motor will not overcome the lock.
Additional pictures: Forest River Forums - dunnnc's Album: Awning lock
Name:	Awning lock engaged front view.jpg
ID:	13781   Click image for larger version
Name:	Awning lock top close up.jpg
ID:	13782   Click image for larger version
Name:	Awning lock turnbuckle.jpg
Old 05-14-2012, 09:12 PM   #2
wagon52's Avatar
Have thought about an awning lock. Question- could you drill a hole through the awning arms and put a pin through to secure it?
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone)
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
wagon52 is offline   Reply With Quote
Old 05-14-2012, 09:28 PM   #3
I have a manual awning I just put a zip tie around the top of each leg and cut them off the next trip when setting up again.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 05-14-2012, 09:29 PM   #4
Where would you drill the hole in the arm? My thoughts are the arms are flimsy enough without drilling another hole. The only way I saw to lock the roller is the roller itself which would require a ladder. I went the way I did as it only required drilling a hole in the motor end tube hub and tapping it to 3/8-16 unc. The rod/turnbuckle unhooks and will be put in the storage area while camping or hooked on the poles.
Old 05-14-2012, 09:34 PM   #5
wagon52's Avatar
Originally Posted by dunnnc
Where would you drill the hole in the arm? My thoughts are the arms are flimsy enough without drilling another hole. The only way I saw to lock the roller is the roller itself which would require a ladder. I went the way I did as it only required drilling a hole in the motor end tube hub and tapping it to 3/8-16 unc. The rod/turnbuckle unhooks and will be put in the storage area while camping or hooked on the poles. I
Not sure, I'm at work and unable to look at my awning. Just a question. I like your mod and wish I had the capability to do it as well. Looks nice!
Old 05-14-2012, 10:42 PM   #6
miatared's Avatar
Now that's an idea, I have a manual awning and it could make sense.
Anyone tried this?
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 05-14-2012, 10:51 PM   #7
Anyone tried this?
Locking the arms will not stop the awning itself from unrolling. I have seen a hose clamp and a picture hanger put on the roller and an aluminum storm door bottoming spring with chain used. By whatever means possible, the roller must be locked to prevent the possibility of having a sail on your trailer.
Old 05-15-2012, 05:40 AM   #8
Snowsail
Snowsail's Avatar
Originally Posted by dunnnc View Post
For less than $20 and less than 2 hrs work, why be the 1st?
I used Velcro, worked great and was a fast and solid tie down.
2013 Rockwood 8280WS signature, diamond package
2011 F-150, FX4,EB,6.5' bed
Snowsail is offline   Reply With Quote
Old 05-15-2012, 09:24 AM   #9
TURBS's Avatar
power awning lock
Dunnnc, how did you attach lower end of bar or is it removable?
Old 05-15-2012, 10:17 AM   #10
The bottom is just the straightened out eye of the turnbuckle that I covered with a pc of the 3/8 pex. Just hooks on the bottom of the awning wall channel.
Name:	Bottom hook unlatched.jpg
ID:	13828   Click image for larger version
awning, led pad
