Old 08-24-2013, 08:44 AM   #101
TURBS's Avatar
Originally Posted by Ragin Cajun View Post
There on there way !
Hawkeyes rule.......
Old 08-25-2013, 06:52 PM   #102
TURBS's Avatar
Fyi I've got enough brackets from oc to make poles to those I have promised and then we're out of mounting brackets till we can get some more made.
Oc and I have sent the specs out to two companies last week and are awaiting cost figures before we can get some more made.
I will post when we have some updates.
in the meantime I should have the four sets made in a couple of weeks.
Turbs.....
Old 08-25-2013, 11:23 PM   #103
Originally Posted by f1100turbo View Post
For all you that have bought awning poles from me there is an updated lower attaching bracket that I reconfigured to be able to lock them securely.
I think I've contacted everyone and your kit may allready have them or I'm shipping out the new pieces.
Bracket in raw form.
Completed.
Turbs
The new version of the bottom mounting brackets I like better than what came with the kit that I purchased earlier this year. Please send me info on how to purchase them.
Mike
mike6065 is offline   Reply With Quote
Old 08-26-2013, 06:13 AM   #104
TURBS's Avatar
Mike
These new brackets will not fit the poles you purchased from old coot.
They only fit the poles I'm currently making from emt conduit.
Ron
Old 08-26-2013, 06:42 PM   #105
TURBS's Avatar
I need to clarify for anyone interested in my awning poles that they are NOT the same poles oldcoot was making.
They are made from emt conduit and are NOT the exact same specs as oldcoots.
The only thing that remains the same is the upper mounting brackets otherwise there completely different.
I clearly stated earlier in this thread that they were emt conduit.
I just want everyone to be clear.
Turbs
Old 08-26-2013, 09:13 PM   #106
Awning Pole
Received my new awning poles today from turbo. Great workmanship, packaged very well, no complaints with the business side of this. Arrived as promised. Now to get them powder coated and installed.
lldsilver41 is offline   Reply With Quote
Old 08-26-2013, 09:17 PM   #107
I have one set left of the alum. poles with me in case someone is interested. PM me for details.
Old 08-26-2013, 09:23 PM   #108
From what I saw of FT Turbs poles in Goshen, they are very well made and should perform well.
Old 08-26-2013, 09:44 PM   #109
Brother Les's Avatar
Originally Posted by OldCoot View Post
This is how the alum poles stow. The pvc poles stow the exact same way.
At the bottom is the pole pinned to the awning support arm? Does the pole sway back and forth going down the road and do damage to the 'paint' from rubbing metal to metal? Can the awning pole be left attached to the support arm in the horizontal position when the canopy is out and not used as a support pole in the vertical position? I guess the pole(s) could be easily detached at the top bolt is I wanted to store them somewhere else and not use them or not want to travel with them there on the awning support arms.
Brother Les
Old 08-26-2013, 09:54 PM   #110
jtstromsburg's Avatar
Yes pinned in a"U" bracket. And it can stay in the bracket, when the awning is deployed, horizontally.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
