Old 07-25-2013, 10:18 AM   #31
Happy Camper
dfrauhiger's Avatar
Would a strap hooked from the awning down to a metal screw in tiedown do the same thing without the pole?
Dave
2012 Ford F-150 Eco Boost
2011 Rockwood Roo 21SS
2012 Days Camped - 24 (2,300 miles, 8 campgrounds)
2011 Days Camped - 12
dfrauhiger is offline   Reply With Quote
Old 07-25-2013, 10:21 AM   #32
TURBS's Avatar
No !
It will pull your awning down as if you had it set for water run off.
Then your door will most likely not open.
Old 07-25-2013, 10:51 AM   #33
Denver, CO
garbonz's Avatar
Originally Posted by f1100turbo View Post
No !
And if you pull to hard, you will break something.. NEED the down poles and brackets to attach them with.
2017 Fuse 23T
Old 07-25-2013, 11:03 AM   #34
golfmedik's Avatar
Last year at Myrtle Beach in an afternoon storm, I saw 6 campers with power awnings that had damage to them by pulling off the side supports. That is why I started looking into the solution and saw OC's pvc posts. And yes, I should've bought the aluminum ones that he was making.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 07-25-2013, 03:30 PM   #35
GASPEDDLER's Avatar
South Padre Island Texas July 2013.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 07-29-2013, 01:30 PM   #36
HemiCab's Avatar
I went and bought the supplies to make the support arms but I have a couple of questions. What size reducer did you use to make the saddle? I found a 2" to 3". What size pin did you use to hold the pipes together? I found a round clip pin with a usable length of 1 3/4" and a square clip pin with a usable length of 3". The DW wanted them painted black so do you think the paint will even stay on the PVC? Couldn't find the Fusion paint but found Rust-Oleum painters touch 2X ultra cover, says it also bonds to plastic. HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
Old 07-29-2013, 01:38 PM   #37
TURBS's Avatar
It will bond to plastic just takes I think like 7 days to cure fully.
1/4 pin to hold two pieces together.
Old 07-29-2013, 02:09 PM   #38
HemiCab's Avatar
Turbs appreciate the info. What length of pin...I want to say to the O.D. of the 2" PVC pipe is 2 3/8 but I couldn't find a pin with that stated usable length, could only find 1 3/4 or the larger 3". May just need to go with a bolt and wing nut combination, author the pin would be easier to keep up with. Any idea of where I could find a 2 1/2 usable length pin? HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
Old 07-29-2013, 02:11 PM   #39
TURBS's Avatar
Farm supply store.
Old 07-29-2013, 02:32 PM   #40
HemiCab's Avatar
Thanks turbs
After looking at the pictures it looks like the reducer (for awning tube) is half a 3" or 4" T with a 2" outlet?? HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
