Old 07-15-2013, 08:15 PM   #21
TURBS's Avatar
Originally Posted by Capt. Mike View Post
Where do they store when you are travelling?
They store up against the awning arm
Old 07-15-2013, 08:18 PM   #22
Originally Posted by sbreen View Post
Old coot what do make yours out of they look like alum. I'm a sheet metal worker here in Baton Rouge Louisiana and I rather use metal for any of my camper projects. Can you take a close up of the poles you make
1"od x 0.083 or heavier inner poles and 1.010" id x .120 or heavier outer poles.
I make the brackets
The poles store right on the awning arms.
Old 07-15-2013, 09:02 PM   #23
golfmedik's Avatar
If that question was directed at me, I store them here.
Old Coot's aluminum ones store on the awning itself, but I made these to carry some of my stuff like the poles.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 07-15-2013, 09:07 PM   #24
This is how the alum poles stow. The pvc poles stow the exact same way.
Name:	Attaching bracket.jpg
ID:	35442   Click image for larger version
Name:	Stow Bracket complete.jpg
ID:	35443   Click image for larger version
Name:	Awning retracting.jpg
ID:	35444   Click image for larger version
Name:	Pole stowed.jpg
Old 07-15-2013, 10:38 PM   #25
Denver, CO
garbonz's Avatar
mine are the same and use OC's upper brackets. I used aluminum telescoping boat poles. 5ft to 9ft. Shurhold
ID:	35448   Click image for larger version
ID:	35449   Click image for larger version
2017 Fuse 23T
Old 07-16-2013, 05:46 AM   #26
TURBS's Avatar
I used oc's mounts and made mine from conduit.
Old 07-21-2013, 05:39 PM   #27
howellma's Avatar
Originally Posted by golfmedik View Post
I know, I know, I should have bought a set from OC, but I've had the stuff to do them for a while now just haven't taken the time until today. I followed the post on the Wildcat Forum but made my inner pole a foot longer than his due to my camper being so tall. Started out with a 10' stick of 2" schedule 40 PVC and 2 pieces of 1 1/2" PVC. I cut the 2" piece in half to give me 2- 5 foot sections. I then cut the 1 1/2" pieces each to a length of 6' long. I drilled a 1/2" hole 5" down from the top of the inner(1 1/2") piece for my anchor point. I then capped the outer(2") piece on the bottom and put the inner one inside. Drilled first hole through both sections, then removed inner and started from the first hole and drilled 3/8" holes every two inches down to two feet from the bottom. Re-inserted it and put the reducer on the top for the saddle. I cut the saddle flanges off with a mitre saw so they wouldn't touch the fabric on the awning. My saddles are going to be removable so that I can store them in my new storage tubes(another mod today and another thread-can be seen in last pic). I know they are not permanently installed but will do for my beach and lake trips! Thanks to the others for the idea.
After having my automatic awning flop up against the camper in high winds last weekend, i tried this and it worked great. the only thing i did differently is that i used a 2" flange cap that has wholes in the bottom so water can run out if it rains.
howellma is offline   Reply With Quote
Old 07-21-2013, 05:48 PM   #28
We will be having 4 raffles at Goshen, first one will be Mon and another Tues., etc. Tickets will be $5 ea., so if you're going to Goshen, you can possibly get a set of self storing poles at a discounted price. Naturally, the more tickets you buy the better your chances. The tickets will only be good for that days drawing.
p.s. I will be bringing the last set of pvc poles I made also. PM me for a price.
Old 07-25-2013, 09:28 AM   #29
Last pole kit loaded-check, 7 pr extra attaching brackets loaded-check, 4 pr brackets for Turbs poles loaded-check, 1 set brackets for Turbs friend loaded-check and finally raffle tickets for 4 sets of poles loaded-check. PM me if you want the last set of OC N T Fab N Chassis awning tie downs.
Old 07-25-2013, 09:50 AM   #30
Newbie 5th Wheeler
Very smart and resourceful people. You should get a patent and start selling them on Amazon and ebay.
hpaden is offline   Reply With Quote
Old 07-25-2013, 10:18 AM   #31
Happy Camper
dfrauhiger's Avatar
Would a strap hooked from the awning down to a metal screw in tiedown do the same thing without the pole?
Dave
2012 Ford F-150 Eco Boost
2011 Rockwood Roo 21SS
2012 Days Camped - 24 (2,300 miles, 8 campgrounds)
2011 Days Camped - 12
dfrauhiger is offline   Reply With Quote
Old 07-25-2013, 10:21 AM   #32
TURBS's Avatar
No !
It will pull your awning down as if you had it set for water run off.
Then your door will most likely not open.
Old 07-25-2013, 10:51 AM   #33
Denver, CO
garbonz's Avatar
Originally Posted by f1100turbo View Post
No !
And if you pull to hard, you will break something.. NEED the down poles and brackets to attach them with.
2017 Fuse 23T
Old 07-25-2013, 11:03 AM   #34
golfmedik's Avatar
Last year at Myrtle Beach in an afternoon storm, I saw 6 campers with power awnings that had damage to them by pulling off the side supports. That is why I started looking into the solution and saw OC's pvc posts. And yes, I should've bought the aluminum ones that he was making.
Old 07-25-2013, 03:30 PM   #35
GASPEDDLER's Avatar
South Padre Island Texas July 2013.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 07-29-2013, 01:30 PM   #36
HemiCab's Avatar
I went and bought the supplies to make the support arms but I have a couple of questions. What size reducer did you use to make the saddle? I found a 2" to 3". What size pin did you use to hold the pipes together? I found a round clip pin with a usable length of 1 3/4" and a square clip pin with a usable length of 3". The DW wanted them painted black so do you think the paint will even stay on the PVC? Couldn't find the Fusion paint but found Rust-Oleum painters touch 2X ultra cover, says it also bonds to plastic. HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
Old 07-29-2013, 01:38 PM   #37
TURBS's Avatar
It will bond to plastic just takes I think like 7 days to cure fully.
1/4 pin to hold two pieces together.
Old 07-29-2013, 02:09 PM   #38
HemiCab's Avatar
Turbs appreciate the info. What length of pin...I want to say to the O.D. of the 2" PVC pipe is 2 3/8 but I couldn't find a pin with that stated usable length, could only find 1 3/4 or the larger 3". May just need to go with a bolt and wing nut combination, author the pin would be easier to keep up with. Any idea of where I could find a 2 1/2 usable length pin? HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
Old 07-29-2013, 02:11 PM   #39
TURBS's Avatar
Farm supply store.
Old 07-29-2013, 02:32 PM   #40
HemiCab's Avatar
Thanks turbs
After looking at the pictures it looks like the reducer (for awning tube) is half a 3" or 4" T with a 2" outlet?? HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
