Old 07-01-2013, 08:27 AM   #1
EastlakeRoo's Avatar
Question Awning Roles up with Crease In It.
Have a 2014 Wildwood 300bh that has a power awning. I noticed that as the awning nears fully rolled up that creases start to show and once fully rolled up the awning isn't nice and flat like it should be.
Is there a fix for this? Hate to do anything that would damage the awning or arms. Just looking for feedback.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 07-01-2013, 08:37 AM   #2
TURBS's Avatar
Mine does the same thing and I've seen many many others that are the same
Old 07-01-2013, 08:38 AM   #3
GASPEDDLER's Avatar
I've noticed that as well with my power awning. Part of it may be due to not having the awning centered on the roll but I think its also normal uneven stretching of the material by the wind.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 07-02-2013, 11:18 AM   #4
Is there a proper way to center the awning fabric on the tube? Do you just tug on the fabric to move either way?
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 07-02-2013, 11:32 AM   #5
mjones12's Avatar
Mine appears to be correctly centered on the tube, but it does the same thing. It is a Carefree of Colorado, and I wonder if the Dometics do it, too.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 07-02-2013, 11:37 AM   #6
Ours is perfectly centered, and also does it. It is just a reflection on the cheap material they are now using for the awning "fabric". Ours has never held any water that might have stretched it, and yet it still hangs down in the center.
The awning on our old camper never sagged, even after 10 years, and having holes punched through it from hail. It rolled up nice and straight until the day we replaced it.
Is it really necessary for the manufacturers to cheap-out on every single component of our not-so-inexpensive campers?
bakken is offline   Reply With Quote
Old 07-03-2013, 07:15 AM   #7
I don't feel bad knowing this is a problem wide spread. Mine has never been out in the rain and it sags in the middle. I guess I will live with it.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 07-03-2013, 07:20 AM   #8
Herk7769's Avatar
Yes; just "flap" it while you tug the material. When properly positioned, so that it rolls up correctly, pop rivet the material to the roller with short 3/16 pop rivets. If you can find the ones with large "rivet heads" even better.
HAM CALLSIGN - KC3FFW
Old 07-03-2013, 07:23 AM   #9
Herk7769's Avatar
This is "normal" in that when the awning is out and the wind is blowing the awning material will flap and slide in the roller. When this happens, the awning may show wrinkles or even bind up the electric awning arms if shifted far enough (about 1/2 inch or so).
Old 07-03-2013, 08:08 AM   #10
Plain Old Member
After reading a while back what herk did, I got home from offshore and adjusted mine as the forward arm was starting to bind up. Straightened fabric up with some minor tugs, arms work perfect now. But, even though the fabric is spot on straight, alligned or whatever you want to call it, it still wrinkles. Doesn't bother me none. Very few I've owned have ever looked just perfect. They serve their purpose. I had read a few ways of putting slack in the fabric, one of which was have somebody push up on the roller tube while others adjusted. Just not easy. What I did was roll it out a 3-4 feet, run a strap on each end from where the roller tube mounts back to the angled brace / shock, and continued unrolling the fabric. The straps on each end hold all the framework in place and you can roll all the fabric off of the roller. Very easy.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
