Old 06-25-2016, 07:53 AM   #11
What do you mean by "stab"?
Sent from my SM-G920V using Tapatalk
2014 Salem Cruise Lite 261BHXL
2016 Chevrolet Silverado 1500
joehbus is offline   Reply With Quote
Old 06-25-2016, 07:56 AM   #12
Stabilizer jack
Old 06-25-2016, 07:58 AM   #13
Ah, thanks
Old 06-25-2016, 08:44 AM   #14
m2kamp's Avatar
Once they reach the ground I tap the button a couple times (rear first) and watch them lift the trailer a tiny bit.
If i just hold the button, my fuse blows before any damage is done (ask how I know)
Trailer still moves a bit. I'm thinking an x-chock or jacks near the tires are in my future.
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 06-25-2016, 08:53 AM   #15
DouglasReid's Avatar
Only for stabilizing
The Lippert Stabilizing jacks are ONLY for stabilizing the camper. the instruction manual tells you to only run the motor for no more than two seconds after both sides make contact with the ground.
The instructions also say they will be damaged if you try and lift the back end with them.
Level the camper buy whatever method you choose and then put them down to stabilize.
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
axle
