06-24-2016, 08:37 AM
Axle Flip question
So I am considering doing the axle flip on my 261BHXL. I've researched enough, I understand how to do it, I can weld myself so putting the new brackets on is no big deal for me. I originally had questions about the stability of the trailer while towing afterwards, but it looks like everyone who has done it has had no issues. My only area of concern is the stabilizer jacks. I have the Lippert power jacks. I assume I would need to build brackets to lower them by the amount that the trailer will be lifted. Thoughts?
2014 Salem Cruise Lite 261BHXL
2016 Chevrolet Silverado 1500
06-24-2016, 08:47 AM
No real need to move the jacks.
Just make some of these.
2X10, 2X8 what ever size you want.
06-24-2016, 08:50 AM
Neat idea Ford do you put a pad under the X block?
Retired Navy
2016 Flagstaff 26 FKWS
06-24-2016, 08:54 AM
Nope.
If the ground was soft I might but every place I have been the ground is so hard I can not drive in the spikes for my patio mat.....
06-24-2016, 06:07 PM
That would defeat the purpose of flipping the axle for extra clearance wouldn't it?
John & Mary Jo
Enjoying the adventure
06-24-2016, 07:07 PM
Left Coast
Probably trying to get trailer level for towing.....
06-24-2016, 07:15 PM
My Wildwood is SOA from the factory with 205/75/15 tires and has lippert power stabilizer jacks (pretty sure they only come in one model). They have no problem reaching my 2x8 pieces of wood, though it does take a while they are slooooow.
2021 Ram 1500 Big Horn LvL2 Quad Cab 4x4 5.7L 3.92
Trailer Steering and Integrated Trailer TPMS
GVWR: 7100
GAWRF: 3900 GAWRR: 4100 GCWR: 17,000
Payload Sticker: 1,867 lbs Tow Capacity: 11,767 lbs
Towing a nice 5th wheel near you
06-24-2016, 07:28 PM
Left Coast
We've found the straighter they are the better they work....some leave the front an inch low, then deploy stabs, raise front....have added a power stab. in front of front axle also
Sent from my XT1585 using Tapatalk
06-24-2016, 08:05 PM
Originally Posted by bob caldwell
We've found the straighter they are the better they work....some leave the front an inch low, then deploy stabs, raise front....have added a power stab. in front of front axle also.
You should only lower the rear stabs and then raise the front IF the rear stab legs are reinforced. I believe Herk found out strictly by accident that it will bend the legs.
06-24-2016, 08:08 PM
Left Coast
I'll agin go stand in the corner......
06-25-2016, 07:53 AM
What do you mean by "stab"?
Sent from my SM-G920V using Tapatalk
06-25-2016, 07:56 AM
Stabilizer jack
06-25-2016, 07:58 AM
Ah, thanks
06-25-2016, 08:44 AM
Once they reach the ground I tap the button a couple times (rear first) and watch them lift the trailer a tiny bit.
If i just hold the button, my fuse blows before any damage is done (ask how I know)
Trailer still moves a bit. I'm thinking an x-chock or jacks near the tires are in my future.
GVWR: 7100
06-25-2016, 08:53 AM
Only for stabilizing
The Lippert Stabilizing jacks are ONLY for stabilizing the camper. the instruction manual tells you to only run the motor for no more than two seconds after both sides make contact with the ground.
The instructions also say they will be damaged if you try and lift the back end with them.
Level the camper buy whatever method you choose and then put them down to stabilize.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
