Old 10-11-2012, 01:49 PM   #11
Nice setup BillT where did you get it from and the brand.
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
browne02 is offline   Reply With Quote
Old 10-11-2012, 02:03 PM   #12
B47
Originally Posted by BillT View Post
Just installed a back up camera in my pick up This is going to make life a little easier. Install a 1" color camera in the rear spoiler on the tail gate. And recess a 7" color monitor in the sun visor. Boy what a difference's. Now on the first shot I'm under the hitch instead of getting out a couple to check alinement Cut a stick the height of the Ball and now just raise the coupler the to the right height and just back under the coupler Well worth the money and time spent to install Took about 6 hours start to finish.
Yes - that will work for hitching purposes if you have a TT. But in my case with having a FW you have to lower the tail gate in order for the king pin to not hit the tail gate. So all you are seeing is the ground/pavement.
BTW - our Ram does have a back up camera system installed and it's great for most things, but it is still a two person task to hook up our FW
Old 10-11-2012, 02:16 PM   #13
Road-King's Avatar
On the after market monitors that I've seen they have two video inputs. I don't know if the Ram OEM monitor does. If it does you could place another camera in the truck bed and add a switch inside your cab to give the camera the 12 volt power.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 10-11-2012, 04:14 PM   #14
B47
Yeah I guess that could work. However after spending $50+ for the truck and the DW and I have a routine worked out when hitching up that works for us with the tail gate down, I don't think I will do it it.
Good idea though.
Old 10-11-2012, 07:11 PM   #15
BillT's Avatar
Thanks Browne I bought every thing from Amazon.co Spent around $90.00 for every thing.I wish I kept the box's that every came in Just do a search for a 7" monitor and a 1" round camera It comes with a 17' RCA cable But it was not long enough for my pick up so I ordered a 25' RCA cord The monitor comes with 2 mounts. Hope this helps
1999 RockWood 2505
2007 Dodge Ram Quad Cab Hemi
BillT is offline   Reply With Quote
Old 10-11-2012, 07:17 PM   #16
Road-King's Avatar
My RCA cable was also not long enough, I used a RG6 coax and crimped RCA jacks on the ends. I have a quad cab with a long bed, my FIL ordered the same camera and his RCA cable was JUST long enough, he has a quad cab with a short bed.
Russ & Kim
2014 Alpine 3600RS
back up camera
