Old 05-21-2014, 01:52 PM   #1
B D HOWie's Avatar
Back-up camera install Coachmen Freelander
Almost finished with the installation of a hardwired back-up camera system. Just need to finish sealing a couple areas to help keep the bugs out.
Camera kit from Amazon <$50
Name:	ImageUploadedByForest River Forums1400695903.258414.jpg
Name:	ImageUploadedByForest River Forums1400695969.442382.jpg
Name:	ImageUploadedByForest River Forums1400696037.368612.jpg
The far point visible at top of screen is about 36' back at ground level. The near point red line is about 6' back, again at ground level. I am really pleased with the picture quality.
I was disappointed with the appearance of the camera that came with the unit so I ordered another from Amazon <$30.
Name:	ImageUploadedByForest River Forums1400696203.437538.jpg
Name:	ImageUploadedByForest River Forums1400696324.882571.jpg
Name:	ImageUploadedByForest River Forums1400696360.849688.jpg
OC thank you for the flashing recommendation for the rear camera back wall mounting cover.
NOTE: I do have one suggestion for others doing this mod related to the rear camera. I believe the camera I ordered separately has a 90 degree viewing angle. I recommend purchasing one with 120-150 degree viewing angle. I think this might improve the near and far viewing limits as well as the lateral.
If anyone is interested in additional information I will be glad to provide more info or pics.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 05-21-2014, 02:11 PM   #2
CLT
Next Gen Camperbot 5000XL
CLT's Avatar
So can this be used when driving down the highway also or is it back-up only?
NO TV!!! NOW WHAT???
2014 Coachmen Apex 259BHSS
CLT is offline   Reply With Quote
Old 05-21-2014, 02:21 PM   #3
B D HOWie's Avatar
I wired into the radio's power supply. This enables me to use it anytime the ignition key is on. It also ensures that it is off when I remove the key.
Paul
Paul
Old 05-21-2014, 02:36 PM   #4
so BD, you got the entire kit with the upgrade for $100-150 complete??
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 05-21-2014, 02:56 PM   #5
CLT
CLT's Avatar
How are you running the wiring for it? It looks as if it is internal.
Old 05-21-2014, 04:18 PM   #6
B D HOWie's Avatar
Yes, the $50 kit has the monitor, a camera, a mounting bracket. It also has a double din (7" diagonal screen) mount for your dash if you have the space to install it there. (I could not figure out a place to move the radio so I did not dash mount the monitor.
Even with the better camera and windshield suction cup mount I purchased and wire, etc. I was well below $150. The wider angle camera upgrades are a little more than $30, but you should still be below or near $150 total.
Paul
Paul
Old 05-21-2014, 04:48 PM   #7
B D HOWie's Avatar
Yes, it is partially internal and partially under chassis.
Name:	ImageUploadedByForest River Forums1400707270.672923.jpg
Rear camera comes in upper cabinet. Then it is routed through the full length closet to the basement.
Name:	ImageUploadedByForest River Forums1400707469.269946.jpg
Name:	ImageUploadedByForest River Forums1400707359.390594.jpg
Our FW tank is under the bed. Wiring is brought from the basement to the FW bay and down and out floor for the under chassis run.
Name:	ImageUploadedByForest River Forums1400707764.502447.jpg
Name:	ImageUploadedByForest River Forums1400707810.513264.jpg
The two white tubes are the FW over flows.
I used RG6 for the video cable and had some difficulty pulling it through the conduit so I just notched the pull boxes and ran it outside. I ran my electrical in the conduit all the way to the front door step well and came back to the interior.
Name:	ImageUploadedByForest River Forums1400708294.117993.jpg
Name:	ImageUploadedByForest River Forums1400708358.550008.jpg
You can go to either driver or passenger side depending on which side of the chassis you follow.
I came up behind the kick panel and ran wires as needed to radio for power and the monitor wiring harness.
Paul
Paul
Old 05-21-2014, 05:52 PM   #8
CLT
CLT's Avatar
Great job on the pics. Looks like it is just something that takes a little time and patience. I might have to attempt this at some point.
Old 05-21-2014, 08:19 PM   #9
B D HOWie's Avatar
CLT
You are correct time and patience.
Ronald Ross with Coachmen was a great help. I emailed him, told him what I was planning to do. I ask about the location of marker light wiring and chase routing. He confirmed that the area on the Freelander between the rear window and marker lights was clear for drilling into upper cabinet.
After noodling out a routing plan I contacted Mr. Ross again and inquired about coming up under the dinette. He recommended the driver's step well since other wires already come in at that location. Pulled the step well cover to look at the routing. (Ron, thanks for all your help and quick responses to my inquiries.) I chose to route to the passenger's step well do to my ability to more easily access that side of the RV with my creeper. I routed on the outside of the chassis frame, running through small framework that was available to support the conduit and video wire. I used zip ties to help secure. Also used Great Stuff to fill between conduit and body where all the conduit entered/exited house. Used rope putty on each end inside the conduit where the wiring comes from camera and enters the upper cabinet. This will keep critters out and not get hard if I need to change camera later.
As is typical the Chinese instructions are minimal. An example is the blue wire on the monitor harness and the kits camera is labeled Aux. no other explanation. I can guess that it may be to hook up a trip power feed for a turn signal or something as the monitor does have the ability to support two video inputs. I just capped it off with a wire nut to be safe. Also be cautious with the video RCA plug. The male exterior contacts are very flimsy.
Best of success when you decide to install yours.
Paul
Paul
Old 05-21-2014, 08:39 PM   #10
CLT
CLT's Avatar
Have you had it out on the road yet? I'm wondering how the camera does with the sun shining on it.
coachmen
