Old 08-13-2015, 06:25 PM   #1
karrun's Avatar
Back up camera wiring help
I did search and didn't find an answer to my specific question. I plan on installing a wired backup camera to my 21SS Roo. For easy intall, I'd like to mount it to the tail light on the rear driver's side because I can access the tail light wiring inside the storage compartment and mount the camera to the license holder. I know I need hot for the reverse and ground, but am not sure what is what for my TT. I took a picture. looks like I have green, black and white coming from the light, but I'm not sure which to use. I took a picture which is hopefully more or less clear.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is online now   Reply With Quote
Old 08-13-2015, 06:51 PM   #2
Does your Roo actually have wiring for backup lights? Our Vibe did not. Three wires as shown would only provide stop/tail lights. I wired the positive camera lead to the running lights. It allows me to turn the camera on by using the running/marker light position of the TV light switch. I can use it for backing or any time I wish see what is to my rear in traffic. PM if you need color code ID (I would need to look).
pjnlorrie is offline   Reply With Quote
Old 08-13-2015, 06:59 PM   #3
karrun's Avatar
Ahh, I guess I assumed that it had reverse lights (and you know what they say about that). I guess wiring it to the running lights would work. I would really appreciate the color code ID.
2016 Roo 21SS
Mods so far:
Old 08-14-2015, 01:23 AM   #4
2007 WildCat 32QBBS
05CrewDually's Avatar
Use a test light or meter to know for sure. But it does look like the white is more than likely your -ground. Black may be the hot for parking lights and the green turn/brake.
You could pull the lense off outside and see what color wire goes where.
05CrewDually is offline   Reply With Quote
Old 08-14-2015, 08:52 AM   #5
karrun's Avatar
Thanks for the suggestion about removing the lens. Looks like you are right about the white, it connects to a metal piece on the bulb holder. Both black and green go to the bulb.
2016 Roo 21SS
Mods so far:
Old 08-14-2015, 12:12 PM   #6
karrun's Avatar
I have a voltmeter but am not very good at using it. I got it out and turned the selector to DC and turned the running lights on. With the bulb removed, I touched one probe to the ground wire and the other probe first to one terminal under where the bulb normally sits and it read 8 (volts DC I am assuming). Then I touched the other terminal and it still read 0. I am assuming that the first terminal (where the black wire terminates) is the one for the running lights, so I should wire my positive wire from the camera to the black wire. Is this correct?
2016 Roo 21SS
Mods so far:
Old 08-14-2015, 12:39 PM   #7
Have you considered a magnetic mounted wifi or bluetooth camera? I saw one sell for just over $100 lately, but I imagine you can find one cheaper. You can also use one smart phone as a camera and another as a remote viewer. Find a smart phone mount that you can attach to the back.
jmichaelo is offline   Reply With Quote
Old 08-14-2015, 01:00 PM   #8
rsdata's Avatar
your voltmeter should give you a Positive + and a Negative - indication when using the black probe for negative and red probe for positive. From any bare metal point on the trailer, or sticking the black probe on the metal part of the bulb holder, with your lights on use red probe to find a wire that should give you 12 volts (or close to that). The Pos indicator is usually BLANK on the meter, but a Neg - indicator will show on the meter screen if your probes are reversed. ANything metal on the trailer will always be the negative grounded side of the battery.
I have my license plate camera hooked to my tail lights, so anytime my lights are on the camera is on.
You will need a long wire to go from camera to display. If you need something longer than what is supplied, order from MCMelectronics.com
Here is a link to a 30 footer for instance...
30' Composite Video Cable;rg59; 75ohm | PSG00565 | Distributed By MCM
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-14-2015, 01:10 PM   #9
karrun's Avatar
Thanks, but I am staying away from wireless as they don't carry signal well over distance.Actually, that is not entirely correct, as I am running a hard wired video cable from the trailer camera to the wireless transmitter I have installed in my TV backup camera, so I am actually wired and wireless. I will unplug my TV video camera and plug in my trailer wire when I am using it.
2016 Roo 21SS
Mods so far:
Old 08-14-2015, 01:23 PM   #10
B and B's Avatar
Looks like a Stab Jack switch. You an get 12 from there to power the camera all of the time. Use your meter to find the 12 volts.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
wiring, back up camera
