Forest River Forums
Sunline User Photos
Old 03-30-2011, 05:17 PM   #1
Iggy's Avatar
Backup Camera Mod for 5th wheel truck
I just recently purchased a new Ford F-250 which came with a backup camera. Well I had to remove the tailgate and install my 5th wheel V tailgate.
I thought it would be neat to have a camera that when backing up see the hitch alignment and would show in the backup mirror.
I puchased a miniture camera and tapped into the power and video circuit at the rear of the truck and installed the camera in my cargo box lid.
Simple wiring and in a few hours I had it done.
Here are the pictures.
This is the camera I purchased. LINK
If you want more info just ask.
2012 Georgetown XL 37' - Model 378TS
Dinghy - 2012 Fiat Pop 2,323lbs
Old 03-30-2011, 05:26 PM   #2
Send a message via Skype™ to scubieman
That is well done. I may need one of those once I get a 5th wheel since I got a Mega Cab!!! Thanks for idea.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 03-30-2011, 05:32 PM   #3
Iggy's Avatar
The only thing I may redo is the wiring. I need to purchase 2 pair stranded wire. I just used some solid bell wire for both the video and power. Works great but I know I can do a better install with the single 2 pair cable.
Old 03-30-2011, 05:37 PM   #4
I used coax cable.. It worked well. Another open is to purchase the factory cable going to the camera. Cut that up and attach your camera to that. So you didn't have to tap into the good factory cable(monitor side).
Old 03-30-2011, 08:02 PM   #5
Rugged Brown's Avatar
i thought you were going to install it in your 3rd brake light.
Terry/Bernadette
Lily the Yorkie
2010 RAM
2011 Flagstaff 8528 CKWS
Rugged Brown is offline   Reply With Quote
Old 03-30-2011, 08:23 PM   #6
Iggy's Avatar
You were right. That is what I was going to do but after I hooked (temp)it up I saw how it saw everything and decided to stay much lower by using my storage box. It was a much easier install and I didn't damage my 1 day old truck. I may reconsider later but now it is working great in seeing the 5th wheel hitch in the mirror.
Old 06-28-2011, 06:32 PM   #7
Warrior's Avatar
Great idea. Why weren't you able to use the OEM camera?
Warrior is offline   Reply With Quote
Old 06-28-2011, 08:24 PM   #8
jimh's Avatar
i did something similar today. i purchased a camera and put it in the center of my bed cover storage box. ran the wires along with wires from a camera mounted to the back of the trailer inside the channel in the bottom of the door frame area to the front of the truck.
i was installing it as a side view camera but it swivels so i thought of the same thing ur doing. i still haven't run power to it so don't know how well it is going to work. i'm afraid vibration is going to make it unusable.
the rear view (on the trailer) is operational so i will see how well it works tomorrow (we are going to Natchez trace parkway campground in southern Tenn tomorrow. if the other camera stays up there, i will look at getting power to it when i get back...cable is run need to reduce bat voltage and tie it in. figure 2 diodes will drop voltage to abt 9v).
bought the camera on the truck from harbor freight for $30.
jimh is offline   Reply With Quote
Old 07-01-2011, 11:19 PM   #9
Iggy's Avatar
No I left the OEM camera in the tailgate and bought the camera online
Old 07-01-2011, 11:21 PM   #10
Iggy's Avatar
Nice ideas. This forum has plenty of great ideas and suggestions.
Iggy
» Online Users: 523
96 members and 427 guests
4bnabird, Al Fresco, amxpress, Big Vic, billy bob, Biscuit, bowshark, Buffalohunter, campnqueen, Canuck_Doug, Char_n_Kath, chiro, cousin01, dashonthedash, daveinpickerington, davidjb, daw592, DDC, DonG, donn, duchie, Elidh, Filthy Beast, firedaniel, freedom 750, gandr96, Gary0848, gimp425, Gman88, Goomph, gucci, herk7769, heytomgraywolf, Hob, honda1, hoovercab, Huey1946, Hydrothunder, jacksum2, Jeep4Two, JJFerg, Joseph5410, jpetrey, kathomas, kb4srn, KKapa, KRS, lochsa, Lumpty, mack63, Mad4sax, maggiek, mamentt, manvel, mraynie, mtl roofer, NanaKaren, NeilM108, newby, NO3putt, NorminN.B., ns-sabre, okdrifter, papap, polkatronron, Poppy Bill, railstar, rbrandon, RGH, rickthelen, RickV, RJHuser, RV Guy, Sahgie, Saratoga Camper, Sawdr73, sherdep, sideout1961, skipper194242, snipe, softwarejoe, sprayking, spurge1947, stevem4134, Tee, thewren, Tincup13, tinker, Titleguy, TopGobbler, troyt, venturetaz, wbdvt, will4u, wnytaxman, yworrydog
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
