Old 09-17-2012, 11:59 AM   #1
wagon52's Avatar
BAL Lock-Arm Stabilizing Bars
Ok, so I got 2 sets of these for my TT. has anyone else put these on? My biggest question is.......should I put both of the sets on the rear or should I put a set on front and rear? Any input would be appreciated.
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone)
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
wagon52 is offline   Reply With Quote
Old 09-17-2012, 12:04 PM   #2
I made my own, but put 4 on the rear and 4 on the front. X'd on the rear with one going forward on both sides and the same X on the front with one going rearward on each side.
Old 09-17-2012, 01:06 PM   #3
wagon52's Avatar
Well since I was working on a budget I only got 2 sets. Just trying to get a feel for what would be the best bang for my buck. Running them along the frame front and rear or or X'ing a set on front and rear or put both sets on the rear.
Old 09-17-2012, 01:16 PM   #4
My budget was tighter than yours, which is why I made my own.
I think I would X them in the back and put one on each side in the front going toward the rear of the trailer. Make sure you have the jacks retracted and hold the stabilizer up to the pad and along the frame and mark the frame to make sure you have sufficient room for the stabilizer to stow.
Old 09-17-2012, 08:13 PM   #5
wagon52's Avatar
Thanks. Wish I had the tools and knowledge to build things like this.
Old 09-17-2012, 10:26 PM   #6
MEMBER
I put one set on one front corner and one set opposite side rear corner
on travel trailer I had. Worked great, wife was very pleased with results.
Banjer is offline   Reply With Quote
Old 09-18-2012, 07:46 AM   #7
lindy's Avatar
like DUNNNC is too made my own brace arms. No real tools needed other then hacksaw, wrench and screwdriver. I bought from Home depot 3, 4' galvinized pre drill angle iron stock, and 4 combo standard/strap hindges. Two of the bars are used for the rear brace, and the 3rd cut in half and used for the front to rear brace at the rear of the trl. The hindged were used at each end of the braces to attach to the frame/jack foot as required. Total cost about $45.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-18-2012, 08:00 AM   #8
I used 1" and 1-1/4" square tubing and spherical rod ends for the 8 I made. Total cost was just under $100 and about 12-14 hrs total time to fab, paint & install.
http://www.forestriverforums.com/for...albums658.html
Old 09-18-2012, 09:29 AM   #9
lindy's Avatar
DUNNNC; I didn't need to go quite so heavy duty being as all I have right now is a Rockwood Ultra Lite 2604, But will keep your pics in mind once we do get our 5th wheel
F.R.O.G. member
Old 09-18-2012, 05:14 PM   #10
The ones in the pictures were what I made for our previous 831RLSS. I just was not going to give them to the dealer to give to someone else.
Old 09-18-2012, 09:22 PM   #11
I bought two sets of these. One in each corner. I believe the instructions said if you are installing just one set is to do opposite corners (one back, one front).
jleon01 is offline   Reply With Quote
Old 09-19-2012, 11:56 AM   #12
wagon52's Avatar
Well I got them installed this morning. No real problems other than I had to get longer self tappers for the rear and had to run one forward an one back on the rear. All in all it was simple an easy and could probably do another set a LOT quicker! Lol I ended up putting a set front and rear and will get another set for the rear over the winter. It seems to be a lot better inside now with a lot less movement. This weekend with the wife and daughter will be the real test though.
Attachment 19683
Curb side rear
Curb side rear
Driver side rear
Curb side front
Driver side front
Old 09-19-2012, 11:59 AM   #13
TURBS's Avatar
hey looks good !
those bal's are just as good for the money as those high dollar deals imo !
i have two on my rear jacks but I put them both forward ......
Old 09-19-2012, 03:55 PM   #14
wagon52's Avatar
Originally Posted by f1100turbo
hey looks good !
Thanks!
