Old 12-29-2012, 12:06 PM   #1
Camper Less Camping
Cajun Po-Boy's Avatar
Bathroom Door Hanger
Needed a rack that was sturdy to hold heavy bth towels and coats/hats.
The stick-on hooks were too unpredictable and I didn't want to nail or screw anything into the wall.
So...I picked up this door hanger and two metal coat rack claws and was able to secure it down on the top of the door with flat head screws. Also ised the back of the door hanger towel holder to screw on the coat hanger pieces...problem solved.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 12-29-2012, 12:13 PM   #2
rattleNsmoke's Avatar
Necessity is the mother of invention... Nice yob mon.
rattleNsmoke is offline   Reply With Quote
Old 12-29-2012, 01:13 PM   #3
Trailer Trash
My other half uses those at home - laundry room and spare bedroom. Makes the assumption you have enough gap between the door and the door's frame. IF not, door doesn't close till you take them off. They also scratch door if you take them off frequently. Other than those issues, they are a wonderful add on.
joelek is offline   Reply With Quote
Old 12-29-2012, 01:49 PM   #4
rip
rip's Avatar
Your idea to fasten it down on the top, leaving holes hidden, is the real genius for those of us that change our minds a lot.
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 12-29-2012, 07:25 PM   #5
Sabre_Ray's Avatar
We just picked up an item like this just the other day, just haven't gone out to put it on the bathroom door yet!!! Definitely a must have for the wife
Ray, Christi and the kids
2013 Sabre Silhouette 291 BHTS
Sabre_Ray is offline   Reply With Quote
Old 12-29-2012, 11:54 PM   #6
Oklahoma Proud
MillerTime's Avatar
Good idea ragin!
Don't know why I didn't think of it, we have several in the house.
Old 12-30-2012, 06:15 AM   #7
We've had something similar in the last two RV's. I drilled a small hole in each bracket where it goes over the door. The off side is flush with the door and the screws go down through the top to keep the towel rack in place. I then use a couple of 3M command strip wire holders to keep the rack tight against the door. No holes show and as I noted, we've moved the same rack now to thee different RV's.
JJnLilly is offline   Reply With Quote
Old 12-30-2012, 10:48 AM   #8
Phat Phrog
RVChick's Avatar
I actually have two of those in my neo-angle shower! One on the outside to hold bath towels, and I hung one on the inside to hold washcloths! When we travel, I just remove them until we get set up again!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 01-12-2013, 11:45 AM   #9
gbpacker's Avatar
Did the exact same thing and for the same reasons.
gbpacker is offline   Reply With Quote
Old 01-28-2013, 08:58 PM   #10
BigTJohn's Avatar
Make sure you either put some screws or finishing nails into the door face into the door frame. We have the over the door rack and the extra weight will cause the door panels, which are only glued to the frame, to slip and it will look like the door has gone out of square. Just thought I'd mention it.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
