04-03-2010, 09:37 AM
battery box upgrade
I currently have a single 12 volt deep cycle battery and am upgrading it to 2 6 volt golf cart batteries. The problem I have is that the current battery is in an enclosed vented battery box that is just big enough to accomadte the current battery. I would like to take the exsisting box out and replace it with a doulbe so I may use the exsisting hole in the bottom of the trailer for spill drainage and the exsisting vent tube for battery gases. Can anyone tell me where I may purchase such a box?
2010 Cherokee 295U 36 foot 5th Wheel.
04-03-2010, 02:53 PM
Here's a link to point you in the right direction. I'm sure there are others out there.
https://www.makariosrv.com/categorie...Battery-Boxes/
Good luck, Charlie
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
04-04-2010, 09:21 AM
04-04-2010, 01:43 PM
thanks, i looked at those links. i think i will either get 2 single boxes (cost around $10-$15 each) and some kind of plumbing fitting to combine the vent or make something "homemade". i cant see paying $90 +$15 shipping for a plastic box.
04-04-2010, 03:31 PM
True, true.
04-08-2010, 01:28 PM
ok so I installed 2 6 volt interstate batteries last night, 232 amp/hours. The battery part was easy, the fun part was the battery box. I ended up finding a box that would sort of work at wallyworld. I found one of the heavy duty black rubbermaid boxes with the red handles in the automotive department. I had to cut the inside 2nd layer of plastic out of the lid for the batteies to fit. I screwed it down, cut the vent hole in the bottom, used some creative plumbing parts to make the drain, drill a couple of holes in the side for the wires to pass through, cut a hole in the top and used a plumbing fitting to attach the vent tube. I will get some pictures and post them. Couple of hours of work but the box and plumbing parts was less then $25 as oppesed to ordering one for $125.
04-08-2010, 02:47 PM
Good deal, glad to hear it worked out for you. $100 saved can buy some other goodies. Congrats, looking forward to the pictures.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
04-08-2010, 09:41 PM
Two questions.....
1. How well does the battery box need to be sealed (excluding the bottom and top vents), does it just need to be reasonably enclosed with a little gap around hole for wires or does it need to be airtight with the exception of the box vents?
2. What kind of water do I use to top off the batteries, regular bottled water, or what?
04-09-2010, 05:59 AM
Lou Amadio
Everything I have read says distilled water ONLY.
As to the battery box (in my opinion), it should be vented to the outside to ensure airflow through the box to the outside. This will purge the hydrogen generated by the charging process does not accumulate and reach a dangerous level. This is normally done with a vent at the bottom and another at the top since Hydrogen is lighter than air. There are plenty of drafts in most battery compartments, but you want to be sure, so vent it. As to how tight, I think it is not so important as long as there is a place to the Hydrogen to GO (UP). The "replacement air" can come in the sides, bottom, etc.
I am in the process of making a double box from two plastic kitchen sink dish washer tubs. I will be using the existing upper vent tube and drilling a drain hole to match up with the existing hole in the bottom of the compartment. Wires will exit through the side where the top and bottom tubs mate. Will photo the whole thing when done.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
04-09-2010, 11:15 AM
I have both the bottom and top vents installed and vented to the outside. I was just trying to figure out if I had to silcone any wire holes on the side of the box.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 518 |
| 94 members and 424 guests |
| 4bnabird, Adony, Al Fresco, amxpress, Big Vic, Biscuit, bowshark, Buffalohunter, campnqueen, Canuck_Doug, Char_n_Kath, cousin01, dashonthedash, daveinpickerington, davidjb, daw592, DDC, DonG, donn, duchie, Elidh, f1100turbo, Filthy Beast, firedaniel, freedom 750, gandr96, Gary0848, gimp425, Gman88, gucci, herk7769, heytomgraywolf, Hob, honda1, hoovercab, Hydrothunder, Iggy, jacksum2, Jeep4Two, JJFerg, Joseph5410, jpetrey, kathomas, kb4srn, ken0042, KKapa, KRS, Lumpty, mack63, Mad4sax, maggiek, mamentt, manvel, mraynie, mtl roofer, NanaKaren, NeilM108, newby, NO3putt, NorminN.B., ns-sabre, okdrifter, papap, polkatronron, Poppy Bill, PrairieBoy, railstar, RGH, rickthelen, RickV, RJHuser, rkswyo, RV Guy, Sahgie, Saratoga Camper, Sawdr73, sherdep, sideout1961, snipe, softwarejoe, sprayking, spurge1947, stevem4134, thewren, Tincup13, Titleguy, TopGobbler, troyt, ugeesta, venturetaz, wbdvt, will4u, wnytaxman, yworrydog |
| Most users ever online was 1,025, Today at 01:04 PM. |
