Old 06-08-2016, 10:49 AM   #1
Battery cut off switch
Could someone tell me why you would put a cut off switch on your camper's battery? How do you do it.
GME2279 is offline   Reply With Quote
Old 06-08-2016, 10:51 AM   #2
TURBS's Avatar
If you don't put in a battery disconnect when not in use and not plugged into shore power the battery will go dead from phantom draws.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-08-2016, 10:53 AM   #3
JustB_Rad's Avatar
I just put mine on last night because over the course of the campers first year, the constant draw from the CO2 detector and radio seems to have killed the battery to the point my awning won't retract without the motor cycling. Replaced the battery, awing comes in fine.
I mounted the switch to the side of my battery box. You will also need to purchase a short battery lead to get from the battery to the switch, then the camper lead hooks up to the other side of the switch.
This is what I used. The knob is removable as https://www.amazon.com/Marinco-701-B...=1&*entries*=0
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 06-08-2016, 10:54 AM   #4
The camper has items that constantly draw power from the batteries. Most single battery campers will go dead in about 3 days and once a battery is fully discharged, it will have permanent damage which is evidenced by reduced capacity.
Having a battery selector switch is an easy way to disconnect the battery without pulling the lug terminal off of the battery each time you want to connect or disconnect.
How to do it:
Buy cable, cut to size for location of switch, crimp or solder connector to battery cable, attach to switch and your are done. Run wire from + terminal to switch.
My fifth wheel has 3 battery banks and each one is switched.
Recommend you use a Blue Sea Systems switch which are easy to rotate and well made. Perko are good switches but wife has trouble rotating them.
Skyliner is offline   Reply With Quote
Old 06-08-2016, 11:10 AM   #5
I have read that some people put it on the - terminal and some put it on the + terminal. Which one should it be put on?
2015 Salem 231 RK
2010 Ford F-150 XLT
Auscon is offline   Reply With Quote
Old 06-08-2016, 11:18 AM   #6
DAISY BOYKIN's Avatar
Which terminal
By all means the + (positive) terminal.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-08-2016, 11:43 AM   #7
NMWildcat's Avatar
I always just put a on/off switch on the negative cable. Easy and you don't have to buy extra cable.
NMWildcat is online now   Reply With Quote
Old 06-08-2016, 11:47 AM   #8
Stormrider151's Avatar
I put mine on the negative terminal. It shuts off everything including my power jack. I can't hook up without the switch being on. To me it's much safer that way. No chance of forgetting to turn it on before pulling out.
Stormrider151 is offline   Reply With Quote
Old 06-08-2016, 12:13 PM   #9
stansoper's Avatar
Installing battery cut off switch.
This is from a previous post of mine. See attached. Would not be without one.
File Type: pdf Installing Battery Disconnect Switch.pdf (1.34 MB, 222 views)
stansoper is offline   Reply With Quote
Old 06-08-2016, 12:31 PM   #10
TGR
TGR's Avatar
My trailer came with a power disconnect switch on the positive terminal that serves me well. It doesn’t disconnect my slide out motors, landing gear nor rear stabilizer but it does turn off all my parasitic draws. If I were to add a battery cutoff switch, I would put it on the negative side of the battery for the same reasons you should disconnect the negative battery post first when removing a battery.
A wrench or tool accidently touching the negative terminal to ground on an installed battery has no effect. After first disconnecting the negative terminal of the battery, shorting the positive terminal to grounded trailer parts with your wrench also has no effect either because the negative terminal is open. On the other hand, accidentally shorting the tool to ground, while disconnecting the positive battery terminal first, can cause a large spark.
This may not be a major concern but it is the reason many advocate putting the battery disconnect switch on the negative terminal instead of the positive one. In either case, the battery is electrically disconnected from the trailer.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
battery
