Old 04-26-2016, 04:03 AM   #1
Casino Camper
jughrad's Avatar
Battery Cutoff Switch Installation - Cherokee TT
I installed a Marinco 701 Battery Master Switch on the battery box of my Cherokee Travel Trailer.
2016 Cherokee 264L (Rear Living)
2013 GMC Sierra Denali
EAZ Lift 1000 WDH w/Sway Control
2017 Nights Camped: 39 Campgrounds: 12
2016 Nights Camped: 24 Campgrounds: 8
jughrad is offline   Reply With Quote
Old 04-26-2016, 06:57 AM   #2
Any pics of the install? I just bought the same battery switch and am looking for ideas on placement.
2015 Dodge RAM 1500 Laramie w/ 4 Corner Air Suspension, 3.92 gears, 32 gal fuel tank, integrated brake controller
2016 Coachman Freedom Express Liberty Edition 320 BHDS
rocketman1083 is offline   Reply With Quote
Old 04-26-2016, 10:45 AM   #3
Casino Camper
jughrad's Avatar
Mostly just video, I would have to capture screenshots. If you can't watch the video, let me know and I will put some pictures up tonight. Perhaps it isn't clear that this is a link to a you tube video of the installation.
Old 04-26-2016, 03:44 PM   #4
Sorry, I didn't realize you had attached a video. Great job on the video and it gave me some great idea on installing mine. I really appreciate it.
Bob
Old 05-20-2016, 12:08 AM   #5
RND
RND's Avatar
Not to be difficult but I have to ask, Why not just take the cables off the battery, unhook them? Unless of course theft is the biggest reason.
2016 Cherokee 274DBH
2015 Ford Expedition Limited
2015 Polaris RZR 570 LE Trail Edition
2012 Polaris Sportsman 500
2009 Yamaha Yz250f
RND is offline   Reply With Quote
Old 05-20-2016, 12:28 AM   #6
I did the same thing a couple weeks ago, I ended up with a different brand but almost identical battery switch.
I took out all 4 knockouts and then dremel'd off the remaining plastic "feet" at the corners to make it shorter to fit under the lid of my smaller battery box.
Didn't think there was any point in putting the bottom plate on the switch as there is nothing exposed that wouldn't normally be anyways.
I didn't have a hole saw the right size and ended up with a hole that was sligthly too large, so I used the extra gap to actually JB Weld the battery switch in place. The dark grey color matched fairly well.
The underside of the switch rests almost perfectly on the battery so there is no movement, and the JB Weld epoxy has made it all one nice uniform piece molded into the cover.
2015/05/04 - 2016 Coachmen Freedom Express 310BHDS Maple Leaf Edition
YEGrolo is offline   Reply With Quote
battery, cherokee, cutoff switch, disconnect switch
