Old 07-11-2012, 10:06 AM   #1
Battery Disconnect
Hello all, new to the forums. Been looking through the Mods and Updates and notice that alot of you have installed battery disconnects. Was wondering what the purpose of this was? I recently switched to a dual battery set up and wanted to see if I should install a disconnect myself?
Also added 4" PVC sewage hose storage since my 26 BH-Xlite only has one small outside storage compartment that gets pretty full pretty quickly.
Thanks.
Bill
bcarlton74 is offline   Reply With Quote
Old 07-11-2012, 10:30 AM   #2
Terier's Avatar
The battery disconnect switch will cut off the power and help keep the battery charged. Those mods threads are some of my favorite posts to read - lots of good ideas.
BTW- Welcome to the forums!
Terier
Old 07-11-2012, 10:56 AM   #3
To keep it charged when? When it's hooked up to the truck it's charging and when the TT is plugged in, it's charging.
Old 07-11-2012, 11:01 AM   #4
Alleged curmudgeon
Vern's Avatar
This is confusing to me as well. My 2013 Windjammer came equipped with a factory disconnect switch, which I have left "on" since buying the trailer about 7 weeks ago, as the camper is almost always hooked up to shore power when not hooked to my truck.
I understood there would be some situations (storage, etc.) where the battery disconnect should be activated (to "off"). Should I be shutting it off for other reasons?
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 07-11-2012, 11:24 AM   #5
My understanding is that if you store your trailer with out having any power to it, the battery disconnect will stop all drain from your battery. Even if you have everything shut off, there is drain on the battery. Over time this will discharge your battery. The disconnect will stop this drain thus lenghten the life of your battery.
cdbus is offline   Reply With Quote
Old 07-11-2012, 11:28 AM   #6
Terier's Avatar
Between trips I keep my TT at a storage place where I do not have access to plug into power. My battery always ended up being dead within days. While the battery can charge somewhat while being connected to the truck while driving it will be no where near the level needed for the TT.
Old 07-11-2012, 11:39 AM   #7
There are 2 reasons why I can think of to disconnect the battery:
1) When in storage, or not being used, to keep the battery charged up and disconnected from all loads. It could go dead within a few days otherwise.
2) If the trailer is connected to a power source for a long period of time, several weeks or months. The reason here is that having a battery ALWAYS on a converter could litteraly boil the battery away since the voltage applied to it is too high. Some battery chargers are fairly sophisticated, but some are not, and converters aren't good chargers so it really depends on your RV. If you plan on keeping the trailer plugged into a source full time and you are not possitive if the batteries are connected to a converter or a poor charger or a good charger, I would disconnect the batteries once charged, and then connect them up periodically to refresh the charge or when needed due to a power failure. There's no need to have the battery connected otherwise if you're plugged into shore power. The only drawback here is if you loose shore power, you don't have seamless switch over to battery power without flpping your cut off switch.
Explanations can be found here: The 12volt Side of Life (Part 1)
(Some really good 12V battery information here)
SCOC is offline   Reply With Quote
Old 07-11-2012, 12:02 PM   #8
Thanks for the info.
Old 07-11-2012, 12:09 PM   #9
RPAspey's Avatar
please remember that ALL batteries self discharge. So even with a disconnect, the lead acid battery will discharge at a rate of around 15% per month. also note that a typical battery will be damaged if it is discharged below 80% of its capacity. true deep cycles can be discharged even more, to about 70% of capacity. of course there are exceptions.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-11-2012, 12:26 PM   #10
Thanks again.
2010 Forest River Cruise-Lite 26 BH-XLITE
Pulled by a 2008 Ford F250 Crew Cab 4x4 PSD
battery, battery disconnect
