Old 06-19-2014, 07:39 AM   #1
Battery Disconnect Switch
I have a 2010 Sierra 355QBQ fifth wheel and would like to install a battery disconnect switch. Can anyone recommend which one is best for an RV? Do I need a single circuit or a dual circuit switch? How are these installed and or hooked to the battery? Are additional cables needed?
OKI Marine is offline   Reply With Quote
Old 06-19-2014, 08:13 AM   #2
fonzie's Avatar
Here is a good start.....
Fonzie
Old 06-19-2014, 11:46 AM   #3
bikendan's Avatar
Blue Sea marine switches are the best out there.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-24-2014, 10:40 PM   #4
OK, I like the Blue Sea Marine switch 6006. Now what size cable(s) wire gauge do I use. I had seen a post talking about 4 and 8
Old 06-25-2014, 06:17 AM   #5
TURBS's Avatar
I used 1/0 cable "overkill"? Probably.
6 ga. Would be fine.
Old 06-29-2014, 05:24 PM   #6
svo
I just got a cheap one from Harbor Freight. On sale they are $2.99. they handle 300 amps too. Also bought a 4 gauge lawnmower jumper wire from Walmart. Removed the negative lead from battery and connected to one side of the switch. Used the jumper from the other side of the switch to the battery. As a bonus, the disconnect switch has a plastic "key", (comes with 2), that can be removed if you want. My key is chained right by the switch so it don't get lost. Amazon has the same switch for $13.52, free shipping.
svo is offline   Reply With Quote
Old 06-29-2014, 06:35 PM   #7
Blue Sea Marine for me. Do not skimp on switch quality.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 06-29-2014, 08:12 PM   #8
Don't understand amps. What is the right amount as far as amps are concerned on the switch? Some connect to the positive side of the battery and others to the negative side. Which is it? I looked at the one from harbor freight. Seems like that one would be in the way of the battery box.
Old 06-29-2014, 08:41 PM   #9
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Just buy a quality switch (the cheap ones will melt and put you in danger). Cut the positive wire in a convenient place close to the batteries and install the disconnect switch. No need to do anything on the negative side. Compare prices!
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-30-2014, 10:56 AM   #10
Grizzlygibbs's Avatar
Blue Sea switches are great! I opted for a Flaming River Big Switch with removable key to eliminate battery drain when away from the trailer or parked at home. It also came with a mounting bracket. It is super heavy duty, waterproof, and vibration resistant.
Name:	ImageUploadedByForest River Forums1404143654.441912.jpg
I may have been the one referring to different wire sizes. My auto parts house made me custom length 4g wires as that is as small of wire as they had. The consensus is that you can go bigger, just not smaller.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
battery, battery disconnect
