Old 02-19-2013, 01:52 PM   #1
TomStacey616's Avatar
Battery Disconnect Switches
When I owned our Outback 21RS, I had installed a Battery disconnect switch to the side of the battery box... reason I had put it there was because it was hidden from view by the propane cover. Now that I have this nice brand spankin' new FR Tracer, with the battery and box in plain sight behind the tanks... I don't want my switch there. How many of you have installed a switch in the nearest compartment and how did you run it? I'm mechanically inclined and do a majority of my own fixes (one, if I CAN do it, i'll do it or at least try to get ideas first before diving in; Two, it's a learning experience).
So, what am I asking, can I see/hear your ideas which will hopefully spark my ideas to get one installed before I take it back to storage.
Thanks!
TomStacey616 is offline   Reply With Quote
Old 02-19-2013, 02:39 PM   #2
John McClain's Avatar
Use a knife switch at the battery post, or istall a switch by your fuse box in the trailer
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 02-19-2013, 02:57 PM   #3
Never thought about doing a switch by the fuse box...
2010 Tundra DC SR5 TRD 5.7L towpkg (gone)
2008 F350 Lariat CC DRW 6.4PSD
2013 PT Tracer 3200BHT
BlueOX SwayPro (used when hauling cart too)
Old 02-19-2013, 03:26 PM   #4
Triguy's Avatar
If I understand you correctly, you are just looking to install the switch so that its away from prying eyes? If so, I can understand that. I placed mine in front of my battery boxes and underneath my propane tanks. You have to know its there to see it.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 02-19-2013, 03:50 PM   #5
prof_fate's Avatar
I cheaped out...I got wingnuts and use them on the batt posts rather than the nuts that came with it. No tools, nothings come loose, as invisible as it gets, and cost under 50c.
Makes it easy to pull the batt if I want as well.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 02-19-2013, 03:52 PM   #6
I did the same thing for a long time, but got tired of wrestling with the stupid battery cover
Name:	Battery shutoff.jpg
Len & Cheri is offline   Reply With Quote
Old 02-20-2013, 08:48 AM   #7
The red switch that Len&Cheri posted is the one I used to have....
I think i'll try to take a look by the fuse panel to see if there is a good spot to put one.. then i'll post some pictures to help the next 3200bht owner...
thanks for the idea everyone.
Old 02-20-2013, 09:28 AM   #8
I put mine in a locked compartment because I didn't want to take a chance of anyone playing with the electric tongue jack. Here's a pic.
Name:	Disconnect switch 004.jpg
comfun1 is offline   Reply With Quote
Old 02-20-2013, 09:41 AM   #9
SYE
SYE's Avatar
On my last 5er I did noty have one either and my battery kept going dead when I was not plugged in so I purchased a battery terminal disconnect switch because it is small and fit under the battery cover. I pais 9.99 for it. I foi=und one online and here is the link.
http://www.summitracing.com/parts/mo...FZE-MgoddVwACA
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 02-20-2013, 09:43 AM   #10
Steve Jackson
sideout1961's Avatar
What exactly is the disconnect switch for? Is it cutting power to the whole camper or is it there for another purpose?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 02-20-2013, 10:02 AM   #11
SYE
SYE's Avatar
All of the campers that I have had have carbon monoxide detectors in them that will run the battery down if it is not disconnected which is not good for the batteries to discharge fully asll the time, so that is why I have them to disconnect the batteries. I have never had a bad battery since I have done this.
Scott & Vicki
2021 4 reserved
Old 02-20-2013, 10:07 AM   #12
TURBS's Avatar
Radio is also a draw.
12v tv if you have one.
Lp leak detector if its separate from the co detector.
Some units have 12v fire alarms.
Turbs
Old 02-20-2013, 10:27 AM   #13
Triguy's Avatar
In general, a battery disconnect is used to simply isolate a battery from its load OR to switch between banks of batteries.
You would isolate in an RV to avoid the parasitic draws mentioned above. The battery will still deplete over time but at a much slower pace. The parasitic draws on my trailer would run my battery bank down to a 50% SOC within a couple of weeks, but my batteries will last several months if disconnected.
The first picture below will allow you to isolate and that is it. This works well for one 12-volt battery or a bank of two 6-volt batteries.
Some disconnects allow more functionality. The second picture shows a disconnect that allows you to switch between batteries, use both batteries or disconnect all. This works well with two 12-volt batteries or two banks with each bank containing two 6-volts. There are several combinations.
Scott
2012 Shamrock 233S
Old 02-20-2013, 10:34 AM   #14
TURBS's Avatar
I have the second disconnect style you've pictured and I like it well.
Old 02-20-2013, 11:11 AM   #15
Steve Jackson
Thanks everyone for the answers. I'm on my first camper and learning a lot here.
Old 02-20-2013, 11:14 AM   #16
TURBS's Avatar
Ooooo I remember my first camper!
Anytime you need something please ask!
We'll get you takin care of!
Turbs
Old 02-20-2013, 11:16 AM   #17
Triguy's Avatar
That's a nice one. I've used that Blue Sea 6007 in boats.
Good to hear!
Scott
2012 Shamrock 233S
Old 02-20-2013, 11:27 AM   #18
SAILINGERIE's Avatar
Doesn't Forest River install a battery disconnect switch from the factory on all of their trailers? My new 2013 Windjammer 3006W has one in the v-nose next to the propane bottles. It is a push-pull switch.
2007 F-350 DRW
2013 ROCKWOOD WINDJAMMER 3006W
SAILINGERIE is offline   Reply With Quote
Old 02-20-2013, 11:30 AM   #19
Triguy's Avatar
Not on my 2012. It came later in the year for Rockwood and Flagstaff hybrids.
Scott
2012 Shamrock 233S
Old 02-20-2013, 12:12 PM   #20
Funny thing... I haven't installed my switch yet and I found one of those in my tool chest last night.. forgot what the heck it was and then it hit me, kinda like a V8 juice.... A FREAKIN BATTERY DISCONNECT!!!
