Forest River Forums
Sunline User Photos
Old 05-27-2011, 08:45 AM   #1
miatared's Avatar
Battery questions: Trojan VS Crown
I am about to buy 2 6V batteries.
Trojan has a new (?) T105 RE - said to be made for renewable energy like solar. Would this one be a better choice for me, than the 'normal T105' ?
Also the dealer is recommending a Crown CR-225 - more or less the same specs as the Trojan and a tad less expensive.
Any recommendations ?
Thanks,
Denis
2011 Flagstaff Shamrock 19 aka Sham Wow
2009 Toyota Highlander Sport
miatared is offline   Reply With Quote
Old 05-27-2011, 09:17 AM   #2
Moderator
Triguy's Avatar
The T-105RE is a little beefier at 67lbs vs the T-105 at 62lbs, which is important because greater weight means more lead (generally). One potential problem is the greater height of the T-105RE at 11 3/4" vs 10 7/8".
I've used Trojan 12 volts in the past and was happy with the battery. I've not used Crown batteries. It looks like the CR-225 has the same capacity and reserve and is 1lb more than the regular T-105 so it should be close if not better. I would go with that if the price is significantly less than the Trojan's.
Or consider the larger T-125 size batteries if you want to give yourself more reserve.
Scott
DW, DD's x 3 and Murphy the Camping Dog - A Golden
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD, P3, Equal-i-zer
Old 05-27-2011, 09:26 AM   #3
Moderator
Triguy's Avatar
I'll also add that I think the biggest practical difference (besides height and weight) between the regular Trojan and the RE is lifespan, warranty and cost. The RE is supposed to last longer, has a longer warranty and is $20 more.
I spoke with someone at Trojan awhile back and that is what I remember.
Scott
2012 Shamrock 233S
Old 05-27-2011, 10:26 AM   #4
miatared's Avatar
Thanks for this, I'll stick with the T105s - as I noticed the posts are different on the T105-RE, I do not want to change my existing connectors.
I just need to get a cable to connect the two batteries together now.
Denis
» Online Users: 517
94 members and 423 guests
4bnabird, Adony, Al Fresco, amxpress, Big Vic, Biscuit, bowshark, Buffalohunter, campnqueen, Canuck_Doug, Char_n_Kath, cousin01, dashonthedash, daveinpickerington, davidjb, daw592, DDC, DonG, donn, duchie, Elidh, f1100turbo, Filthy Beast, firedaniel, freedom 750, gandr96, Gary0848, gimp425, Gman88, gucci, herk7769, heytomgraywolf, Hob, honda1, hoovercab, Hydrothunder, Iggy, jacksum2, Jeep4Two, JJFerg, Joseph5410, jpetrey, kathomas, kb4srn, ken0042, KKapa, KRS, Lumpty, mack63, Mad4sax, maggiek, mamentt, manvel, mraynie, mtl roofer, NanaKaren, NeilM108, newby, NO3putt, NorminN.B., ns-sabre, okdrifter, papap, polkatronron, Poppy Bill, PrairieBoy, railstar, RGH, rickthelen, RickV, RJHuser, rkswyo, RV Guy, Sahgie, Saratoga Camper, Sawdr73, sherdep, sideout1961, snipe, softwarejoe, sprayking, spurge1947, stevem4134, thewren, Tincup13, Titleguy, TopGobbler, troyt, ugeesta, venturetaz, wbdvt, will4u, wnytaxman, yworrydog
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
