Old 10-10-2013, 11:36 PM   #1
Battery relocation
I have a 2014 Wildwood TT where the battery box is just behind the propane tanks and strapped to the trailer chassis. I remove the battery during storage and have it on a charger at home. I literally have to move one of the propane tanks out of the way to just get to the battery box, so I was thinking of moving the battery to the front outside storage compartment and leave a bus bar connection (covered) where the battery box was just in case I have to use jumper cables. The battery box will just clear the storage compartment door without the cover on. I can install the cover once the box is inside of the storage compartment.
I guess once a gearhead always a gearhead!
tosh99 is offline   Reply With Quote
Old 10-11-2013, 12:00 AM   #2
Twisty's Avatar
I had to move the tanks forward on the tongue to install the WDH brackets.
Is that an option for you?
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 10-11-2013, 12:19 AM   #3
Ford Idaho's Avatar
I would suggest you vent the battery box to the outside of the trailer.
Old 10-11-2013, 01:07 PM   #4
RPAspey's Avatar
if you're going to all that trouble, put the battery box on a slide so you can just pull it out to service.
If you have the standard battery box, it's very tall campared to the battery height. It's also open vented. You might want to get an aftermarket box. One that's shorter and sealed, but with a vent connection. You should have it vented, preferably to the outside of the chasis.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
battery, cat, location
