Old 09-26-2015, 09:42 AM   #11
riznfall's Avatar
I believe the two 6volt batteries will have a much higher capacity. If you have the room that's what I would use. And I wish I had the room. I can only fit one 27 series single battery. They will need to be wired in series to get your 12vdc. And as long as they are wired correctly and with the proper sized wire (which is either 0-2 gauge) you won't have any problems with warranty.
Tim
2015 Ram 3500 Laramie CCLB dually
2015 39R12 Vengeance touring edition.
Tim
Vengeance touring edition 39R12
2012 Dodge Ram 3500 DRW
riznfall is offline   Reply With Quote
Old 09-27-2015, 11:30 AM   #12
Tim
Look at AGM batteries. They are a sealed batteries so you don't need a vented battery box. They are more expensive but worth it.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 09-28-2015, 10:59 PM   #13
Dabmeb's Avatar
Originally Posted by leefl View Post
but is it twice as much ?
If you put 2x 6v batteries, with say 80Ah capacity (random value) in series, then you get 12v at 80Ah, so 960Wh
If you put 2x 12v batteries, with say only 50ah capacity each in parallel, then you get 12v at 100Ah, so 1200Wh
The Amp-hour rating of the 12v batteries would have to be less than half of the capacity of the 6v batteries to make 2x 6v batteries be more effective than 2x 12v batteries
Now, if space or weight is a concern, then two high-capacity 6v batteries may make more sense than two average-capacity 12v batteries, since they might be close to the same power but the 12v batteries will like be larger and heavier
Approximate numbers are 140 to 170 AH for two 12 volt and 180 to 220 AH for two 6 volts
Dabmeb is offline   Reply With Quote
Old 09-29-2015, 08:06 AM   #14
leefl's Avatar
So the 12v are only 70 to 85 Ah each, but the 6v are 180 to 220 each ?!?
Remember that for 2x 12v in parallel you double the individual Ah rating, but for 2x 6v in series you don't, so it's just the per battery rating
leefl is offline   Reply With Quote
Old 09-29-2015, 08:32 AM   #15
Witch Doctor's Avatar
What it comes down to is how you use your unit. If you stay plugged in all the time then two duel use 12v would be best cost wise and for your useage. If you do alot of off grid camping then 6 volt is the way to go. I have 2 12v in the same unit going on 4 years now, but I don't camp without electrical. If your going to hook them up go pos to pos and neg to neg and connect the second battery to ground instead and disconnect the first one simple to do.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-29-2015, 09:10 AM   #16
DKRITTER's Avatar
I agree with this, in our old PT 327RES it came with one 12V NAPA marine battery that had 105AH if I remember correctly it was simple to go to NAPA and just get another one and add it to the trailer and was the most economical also.
We only go off grid a couple of times a year and have a 50AMP plug at the house where we store the trailer. One time we were on our way to Wyoming and hooked up at a RV Park right before a storm hit and we all lost electricity for the night. We pretty much had everything we needed with the 2 12V batteries.
The new trailer is a 5th wheel with a residential fridge and an inverter we opted to go with 4 6V batteries wired in both series and parallel giving us 12V and a little over 400aH. If we dry camped a lot more I probably would have opted for a dual fuel fridge or more batteries but we donít. I need a day maybe 2 of battery power at most.
Like almost everything there is no one size fits all for this either.
DKRITTER is offline   Reply With Quote
Old 09-29-2015, 01:33 PM   #17
Georgia Frog Rally 2018
aceinspp's Avatar
I installed 2nd 12 volt o my tt and previous ones I've had and had very good results. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 09-29-2015, 09:53 PM   #18
leefl's Avatar
I just have the stock 12v battery, and don't expect to change that for some time.
The only usage the battery gets is for the landing legs and stabilizers, and slides. We always camp with power and don't have any plans without.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
Old 09-30-2015, 08:45 AM   #19
You never know what is going to happen. Power loss due to a storm or a bad electrical hook-up, and sso on. One of the reasons I put the second battery in. My second one is an AGM gel battery with 100ah rating. I really like this type of battery because it is sealed so don't have to have it vented to the outside and no battery box required.
If I upgrade my batteries next year I will go with 4 six volt AGM batteries. More expensive but longer battery life and higher ah rating. And again, no venting required.
Jim
George Bernard Shaw
Old 10-03-2015, 11:39 PM   #20
Asking for opinions about 2 x 6 in series vs. 2 x 12 in parallel is like asking if gas is better than diesel or Ford is better than Chevy. You'll get many different opinions, most of which are valid for the reasons the poster claims. Your reason for choosing one over the other should be based on how you intend too use it.
I chose 2 x 12 because it met my capacity needs, was more economical, I don't dry camp very often, and because I have a purpose for them when not camping that requires that they be used separately, at 12v.
One thing to consider is redundancy. Others will state that a 6v battery rarely fails, and they'd be correct. But when one does fail you have only 6v left, which is useless. If you have 2 x 12 in parallel and one fails, you still have 12.
Those are my reasons for what I chose. It suits my purpose but I may have chosen 2 x 6 under different circumstances.
If you do choose 12v, make sure you get true deep cycle, not marine dual
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
12 volt, battery, replacement
