Old 12-12-2014, 09:03 PM   #21
We'll have to get clarification from the OP...
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-13-2014, 06:34 PM   #22
The wire is about 15 feet each way so 30 feet. I measured about a .24 volt drop at the switch compared to off the battery. Going to put a switch in the battery box.
rsv4pilot is offline   Reply With Quote
Old 12-14-2014, 06:55 AM   #23
I stand corrected. That is a long way. So yes if you can put the switch at the battery and shorten that run it would make your system more efficient.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 12-14-2014, 10:23 AM   #24
And switch to LED lights if you haven't already.
2010 Chevy Suburban
Old 12-28-2014, 04:10 AM   #25
An update. Relocated the BSO switch to the front of the trailer and removed 19 feet of 6awg wire.
Trailer is new and already has LED lights.
Replaced the WFCO converter/charger with a Xantrex inverter/charger so we can watch tv at night without the generator running. So far I'm very impressed!! Waiting till spring to replace 12 V marine battery with Trojan T-145's.
Old 01-07-2015, 01:55 AM   #26
The load depending on the circuit, if series or parallel. If it is a series circuit the total number of the load is added to the sum of the circuit. As parallel circuit is a lower amount of amperage and more efficient. Led lighting is also a Lowest forum of load on the circuit draw. I would also install a load protection device near the Power supply to insure that the circuit is protected. Happy wiring.
jimmyt11664 is offline   Reply With Quote
battery
