Old 03-02-2015, 04:14 PM   #11
mike.t's Avatar
mount
Originally Posted by TURBS View Post
My o.k is not in a slide. I may have "dabbed" some sealant in the area of said mounting rail.
Where did you mount it?
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 03-02-2015, 04:14 PM   #12
Originally Posted by mike.t View Post
Also thinking of mounting it on the storage entry door.
Make sure you use a backer inside the door for it. My 08 Flagstaff 831RLSS came loose from the wall the first time we used it and they had to go inside and put a backer board and longer screws. If you're going to put it on a door, you definitely will need the backer.
Old 03-02-2015, 04:14 PM   #13
geotex1's Avatar
Bracket is seperate and you have to get the PROPER one! There are two styles for sidewall accessories like the Sidekick, and you need the K-style. Be sure to use Dacor butyl tape behind it and hit some framing! This is what you need and a great price for it:RVQ 902 - 14-6350 Grill Mounting Extrusion - Price: $8.19 - Factory RV Surplus - 1611 W Bristol St, Elkhart, IN 46514 (800) 325-1461 (574) 262-3327
geotex1 is offline   Reply With Quote
Old 03-02-2015, 04:15 PM   #14
TURBS's Avatar
I'll be home in 30 minutes I'll get some pictures.
TURBS
Old 03-02-2015, 04:16 PM   #15
Toad Haul's Avatar
Thanks Turbs! I just bought the bracket yesterday at CW and wondered if I'd get some tips here on mounting it.
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 03-02-2015, 04:18 PM   #16
TURBS's Avatar
Biggest thing is hitting solid wood which is why I mounted it fairly low so I could hit the decking for the floor.
TURBS
Old 03-02-2015, 04:23 PM   #17
Toad Haul's Avatar
That makes sense. I have a Class C now that did not come with the rail. I likely won't hang a grill on it ,but I have a small, 16" table that has the same rail. I want to place that somewhere to hold my "guy stuff" outside....
Old 03-02-2015, 04:23 PM   #18
mike.t's Avatar
So i assume it is all low pressure gas after the regulator so i can tie in to the steel gas pipe somewhere so i can use the T/T propane?
2014 Dodge Durango
Old 03-02-2015, 04:25 PM   #19
TURBS's Avatar
Mine already had a line there for my o.k cooktop.
TURBS
Old 03-02-2015, 04:30 PM   #20
geotex1's Avatar
Did that with my last TT too! Fabricated up a nice BIG shelf out of aluminum with folding supports that hung off the bracket. Never used the grill at all - stayed boxed in the garage till we sold that TT.
bbq
