Old 03-02-2015, 04:31 PM   #21
trbomax's Avatar
I put an extrusion like that on our LQ horse trailer.Its not worth spit. Thae grille does not hang level so all the drippings go in the burner section instead of the pan. If you try to shim it level,there is not enough of the extrusion left to securely hold the grille.On the new trailer I'm just getting a simple folding stand to sit it on.Dont waste your time or $ on the extrusion thing.
trbomax is offline   Reply With Quote
Old 03-02-2015, 04:33 PM   #22
TURBS's Avatar
Don't have a problem with mine sitting level.
Used it for 10 years now and two different trailers.
TURBS
Old 03-02-2015, 04:34 PM   #23
geotex1's Avatar
Must not have been an actual Sidekick because their bracket has two adjustable feet on the low bar that bears against the camper to adjust the tilt with. You probably have/had the old RVQ.
geotex1 is offline   Reply With Quote
Old 03-02-2015, 04:39 PM   #24
trbomax's Avatar
mines only 2 yrs old,but it doesnt have adjustiable feet.That is why I shimmed the feet about 1/8" where they contact the side of the trailer.With this done,all it took was to bump it and it would fall out of the extrusion.
edit) I just looked at it,its an RVQ 100.
Old 03-02-2015, 04:46 PM   #25
geotex1's Avatar
Yeah, the RVQ support design is notorious for functional issues as you describe. I clearly remember a long thread on it over at RV.net after a camper got 3rd degree burns when one fell off the wall!
I'll take my 10 year-old Portachef any day!
Old 03-02-2015, 05:12 PM   #26
TURBS's Avatar
ID:	70563Click image for larger version
ID:	70564Click image for larger version
Pretty dark in the shop but I think you get the idea.
TURBS
Old 03-02-2015, 05:20 PM   #27
mike.t's Avatar
bbq
Originally Posted by TURBS View Post
Mine already had a line there for my o.k cooktop.
TURBS
Am i correct in thinking not to use a regulator on the BBQ cause it is already low pressure?
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 03-02-2015, 05:21 PM   #28
Toad Haul's Avatar
Where did you get your rail, Turbs? That looks a lot longer than the 16" one I bought yesterday.
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 03-02-2015, 05:29 PM   #29
TURBS's Avatar
Rvq is low pressure.
TURBS
Old 03-02-2015, 05:30 PM   #30
TURBS's Avatar
Cheyenne camping center in stock.
Www.cheyennecampingcenter.com
TURBS
bbq
