Old 03-02-2015, 05:38 PM   #31
geotex1's Avatar
Originally Posted by Toad Haul View Post
Where did you get your rail, Turbs? That looks a lot longer than the 16" one I bought yesterday.
See my post a few above. Good price! I've had great service from them over the years too.
geotex1 is offline   Reply With Quote
Old 03-02-2015, 06:55 PM   #32
mike.t's Avatar
Originally Posted by TURBS View Post
Rvq is low pressure.
TURBS
The BBQ i ordered comes with a regulator to screw a bottle on it. The T/T already has a regulator on it. I don't think you should use 2 regulators.
Try'n to learn.
Mike
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 03-02-2015, 07:00 PM   #33
geotex1's Avatar
Try'n to learn.
Mike
Correct. You will see that regulator is on a quick-connect. When you hook it to the house low pressure supply, you go straight into the quick-connect. They give you the regulator so you can picnic with the grill and use 5# cylinders.
Old 03-02-2015, 07:11 PM   #34
mike.t's Avatar
Thank you. Most RV stores sell the hose's and quick disconnect i need to complete the project?
2014 Dodge Durango
Old 03-02-2015, 07:41 PM   #35
geotex1's Avatar
The best QC is this one: MB Sturgis Inc 104052 Sturgi Stay 1 4" Model 250 Female Quick Connect | eBay
That's what you will need if your TT isn't plumbed with an outside propane QC. How you have to tee into the house main depends on what the factory used - black pipe, soft copper, etc.
For the hose, you can buy them most anywhere if your TT doesn't have a pull-out whip with the QC on it. Something like this one: RV Dual Quick Connect Hose - RV Model 250 Quick Connects & Hoses - SturgiSafe RV Propane Products (LP Hoses, Sturgi-Stays, Quick Connects & Regulators)
However, I generally have my local propane supplier make up whatever I need as they can crimp custom, high or low pressure, and any fitting. Have also used MB Sturgis directly while on the road - they'll custom crimp anything as well!
Old 03-02-2015, 07:45 PM   #36
mike.t's Avatar
Could someone look at this and tell me if it will mount on to a bracket you have provided me info of. To say the least i am confused after visiting the manfactures site.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
2014 Dodge Durango
Old 03-02-2015, 08:04 PM   #37
geotex1's Avatar
We all provided you links to the same style "K" rail, just different websites. The 16.5" is commonly found and will hold just the grill. It is also available in 30" and 36" lengths, but it's harder to find now that so many manufacturer's have switched over to the bumper hangers for their grills. If you are ordering from Amazon, here it is at their price: http://www.amazon.com/Camco-57268-Mo...E6J60B810E8G9N
Old 03-02-2015, 08:14 PM   #38
mike.t's Avatar
Originally Posted by geotex1 View Post
We all provided you links to the same style "K" rail, just different websites. The 16.5" is commonly found and will hold just the grill. It is also available in 30" and 36" lengths, but it's harder to find now that so many manufacturer's have switched over to the bumper hangers for their grills. If you are ordering from Amazon, here it is at their price: Amazon.com: Camco 57268 Mounting Rail for Grill: Automotive
Sorry about all the questions. The Camco 57268 is a "K" rail type? Also you say it will hold "just the grill"?
Thanks again
2014 Dodge Durango
Old 03-02-2015, 08:23 PM   #39
geotex1's Avatar
Thanks again
Correct. It didn't earn the moniker of "grill mounting rail" till those things came out. It was around a longer in the marine industry and referred to as K rail. There a second type of common rail for RVs to mount removable table tops, counter extensions and the old high-pressure outside cooktops (ala old Coleman and Fleetwood PUPs) that doesn't work with the Sidekick or RVQ properly. That rail is called "table support rail" in the RV industry, but is known as "J" rail in the extrusion industry. Confused yet!
Old 03-02-2015, 08:42 PM   #40
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
There's also a bumper mount style of mounting rail like on our original TT by Jayco....this was for a Sidekick to start with but I later changed the grill to something larger which you see in the pics.....When we traded in late fall for our 2014 Silverback 33RL, I fabricated a rail similar to what we had had and added an outside grill to our 5th wheel. You can see it in a thread I posted a few weeks ago...... Added Outdoor Kitchen.
ID:	70578   Click image for larger version
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi...
2017-65 nights/6992 mi.; 2018-47 nights/7376 mi; 2019-11 nights booked
jtownstumpjumper is offline   Reply With Quote
bbq
