Old 03-04-2015, 09:57 AM   #51
mike.t's Avatar
I am going to tap in to the LP system with black gas pipe and run it out the the side by the BBQ. It will be next to the trailer frame. Any mounting suggestions?
Thanks again
Mike
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-04-2015, 10:11 AM   #52
We've used one since 08 and never had the awning retracted while using it, that's what the awning is for is to cover that area. The heat is dissipated before it has any effect on the awning and there is no splashing on the camper side as the lid protects the sidewall. A lot of unwarranted concern IMHO.
Old 03-04-2015, 10:12 AM   #53
TURBS's Avatar
I regret saying this but I agree with oc 100%
Old 03-04-2015, 10:20 AM   #54
geotex1's Avatar
Thanks again
Mike
My guess it that you'll need to break open the nearest union or tee and add in another, so you'll be needing a flexible whip to connect to the QC. Protect that whip with some automotive split-loom IMO, and then use stainless, cushioned loop clamps to secure. If your black pipe runs at the bottom flange of the frame rail like on most enclosed underbellies, you might be able to not use a whip at plumb with black pipe. If you do that, be sure to support that short length with a hanger so it doesn't come loose in travel! Finally, make sure the QC is tucked under a bit so you don't snag anything!
geotex1 is offline   Reply With Quote
Old 03-04-2015, 10:32 AM   #55
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Thanks again
Mike
My grill I added on our 5th wheel was near the front(front storage compartment) so I broke into my propane line where my flex hose from my tanks connected to the cast iron pipe...put a "t" there...got with my local plumbing store to make sure of correct threads, added fittings and then added the Quick Connect to the end....got the QC and a 10 ft QC hose from Amazon and it connects to my grill. I've since added a couple of hangers to help support this attachment during travel.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 03-04-2015, 11:09 AM   #56
mike.t's Avatar
On my way to Home Depot. Thanks geo/jtown and i agree with oldcoot.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-04-2015, 11:52 AM   #57
Be careful with thread sizes....some of the fittings at Home Depot had different threads than the threads on the Quick Connect pieces....I kept leaking when I would put it together even with the yellow teflon tape...finally went to my local plumbing store to get my fittings and the guys there made sure everything had the right threads...might not be a problem for you but was for me.....check all propane connections for leaks.
Old 03-04-2015, 07:46 PM   #58
mike.t's Avatar
Got a 90º fitting attached it to my main gas line then ran a 3' 1/2 gas pipe out to the side (not all the way) where the BBQ will be. The main line runs north and south and the added on line runs east and west just under the main line. Need an idea on how to stabilize the added on line where it meets the main line.
Thanks guys
Mike
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-04-2015, 07:52 PM   #59
mike.t's Avatar
If you will imagine what the top of a cross looks like.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 03-14-2015, 09:35 PM   #60
mike.t's Avatar
Hi guy's. Gas pipe is installed. Bracket is on. Received my 10' propane hose and QC fitting's today. Install tomorrow and leak check.
Thanks again
Mike
2015 Salem 27RKSS
55' Chevy Bel-Air
bbq
