Old 03-14-2015, 09:49 PM   #61
geotex1's Avatar
Originally Posted by mike.t View Post
Hi guy's. Gas pipe is installed. Bracket is on. Received my 10' propane hose and QC fitting's today. Install tomorrow and leak check.
Thanks again
Mike
And the beers and burgers will be where and when?
geotex1 is offline   Reply With Quote
Old 03-14-2015, 09:57 PM   #62
mike.t's Avatar
Hope to arrive in Goodyear AZ around 3:00 pm Mar.21st
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 03-15-2015, 06:58 PM   #63
mike.t's Avatar
Well up and working and no apparent leaks.;o)
2014 Dodge Durango
Old 03-17-2015, 06:52 PM   #64
Summer2Go
Summer2Go's Avatar
I had a grill on the side of my Rockwood Popup for 10 years. I can't see there being any heat problem. The bracket for the grill holds the grill out from the camper wall. They are not great big grills, mine was the 2003 model, and they have changed a bit since then. I did melt the temp knob a little in the beginning, so I know it was getting pretty hot. The side of the camper was never hot to the touch.
Summer2Go is offline   Reply With Quote
Old 03-24-2015, 02:51 PM   #65
mike.t's Avatar
Arrived AZ around 5o pm Used the BBQ 2x. Don't get a strong blue flame more of a yellow. Tried it with a bottle and same weak flame
2014 Dodge Durango
bbq
