Old 03-02-2015, 02:29 PM   #1
mike.t's Avatar
BBQ bracket
Has anyone installed a bracket on their travel trailer to hang a BBQ on?
Any help or videos would be appreciated.
Mike
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 03-02-2015, 02:36 PM   #2
wmtire's Avatar
Are you referring to the mounting rail, that let's you use a BBQ grill like the Sidekick, Olympian, or RVQ?
http://www.amazon.com/Camco-57268-Mo.../dp/B0014JBYTC
http://www.rvqgrill.com/
http://www.campingworld.com/shopping...FQkkgQod3SgA6w
http://www.walmart.com/ip/Camco-Olym...Grill/29764622
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 03-02-2015, 02:39 PM   #3
TURBS's Avatar
I installed a slide bracket for a rvq grill.
I don't have a pic but I can get one tonight.
I hung mine so the screws went into the floor of the rv.
pre drilled the holes thru the fiberglass side then filled the holes with silicone, put silicone on the screws and then siliconed around bracket.
TURBS
Old 03-02-2015, 02:45 PM   #4
Mojojojo's Avatar
TURBS
Turbs did you use any sealant on that thing...... I'm awaiting pics I have the outside kitchen but don't trust the brackets holding it on they look a little sketchy as well as under engineer'd
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 03-02-2015, 02:48 PM   #5
TURBS's Avatar
I have the out side kitchen to.
I'll get you some pics this afternoon.
YES you must use plenty of silicone!
You do NOT want to get water in there otherwise the side could potentially delaminate.
TURBS
Old 03-02-2015, 02:59 PM   #6
mike.t's Avatar
WM. Yes. Ordered a sidekick. Looks like the 57268 is the most common. Don't know if it comes with one just trying to get prepared were heading out in 3 weeks.
Mike
2014 Dodge Durango
Old 03-02-2015, 03:00 PM   #7
TURBS's Avatar
Mike
Wall mount I had to buy separate.
TURBS
Old 03-02-2015, 03:02 PM   #8
mike.t's Avatar
Also thinking of mounting it on the storage entry door.
2014 Dodge Durango
Old 03-02-2015, 03:02 PM   #9
Mojojojo's Avatar
TURBS
Is yours in the kitchen slide area? Did I read somewhere that you used sealant
Old 03-02-2015, 04:05 PM   #10
TURBS's Avatar
My o.k is not in a slide. I may have "dabbed" some sealant in the area of said mounting rail.
bbq
