Old 06-18-2016, 07:57 AM   #11
Wolverine 1945's Avatar
If you could run it with the cover off,,, where would the air go ???
Wolverine 1945 is offline   Reply With Quote
Old 06-18-2016, 11:29 AM   #12
waiter21's Avatar
If I run it with the cover off, the air blows straight down. When I cut holes in the cover to mount the louvers, one of the louvers is directly under the blower so air passes right through it and blows straight down when that louver is opened.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-18-2016, 07:16 PM   #13
Where is a good place to get filters. Mine is very then sponge like material. It can easily be out of place.
GME2279 is offline   Reply With Quote
Old 06-18-2016, 07:44 PM   #14
Brilliant idea! I'm going to order the louvers and do the same mod.
My camper was made in 2013 and has the exact same ceiling cover. So it's not just the older units that are like this. :-)
Thanks!
Mike
Mike Schultz
Mikeschultz85 is offline   Reply With Quote
Old 06-18-2016, 08:05 PM   #15
waiter21's Avatar
Mine uses a sponge foam filter. You can get them at any hardware store and cut it to size.
Old 06-19-2016, 04:48 PM   #16
Personally I think that was a darn good idea, cleverly and neatly constructed. On my unit, which is a ducted model, the cold air comes out next to the return air inlet. I got to thinking about this and wondered how much of the cold air goes right back into the return side with the dump open. First I did a smoke test done with a small smoke bomb bought at a local safety supply store. I was really surprised at how much cold air was going right back into the return grill. I took an ordinary manila file folder and taped it between the return and outlet grills. There was no doubt that the A/C performed better with more cold air being sent into the room. With the A/C grill set in the ducted position this is not a problem. Another smoke test proved that the cold air was coming from the registers in the camper and going back into the return air grill. I'm thinking of making something I can attach to the inside cover of the A/C when we first set up to help cool the TT down faster.
Thurman is offline   Reply With Quote
Old 06-22-2016, 03:37 PM   #17
Too old to be too smart
SpringerPop's Avatar
My A/C/ cover looks identical to the OP's, and I WILL be doing this mod!
Pop
2004 Terry 250RKS, perfect for the two of us and the pups. It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-28-2016, 07:20 PM   #18
Thank you so much for this. Just got mine installed, tested it out, and the DW told me to give you a big smooch! :-) What a difference that makes!
Mike
Name:   ImageUploadedByForest River Forums1467159597.001698.jpg
Mike Schultz
Old 06-28-2016, 11:16 PM   #19
Blktegra's Avatar
Great idea to help your unit out. The thought never even crossed my mind. I'm so anal about checking everything with a moisture meter after every time it rains and keeping the darn thing clean sometimes I overlook the smallest things. After reading this I discovered I have the sliding vent like the pic in the 3rd post. And although while open it cuts most of the airflow off to the rest of the hauler, it gives quite a nice cool down to the main area. Once the temp felt down I just closed her back up and sent the air on its normal path. Thanks for sharing your idea!
2013 Ultra work and play 275ULSBS
Towed by 98 2500 Dodge Cummins hand built by me
Polaris RZR couple of Ski Doo REVs
Blktegra is offline   Reply With Quote
Old 06-29-2016, 12:14 AM   #20
Finished mine today. Didn't take any photos, but it looks identical to these.
GREAT mod, and I highly recommend it for non-ducted rooftop RV A/C units.
Made a BIG difference in airflow!
Pop
