Old 07-13-2018, 04:51 PM   #1
Question Bed/ward/closet modification
Trying to make more space when I sleep. The "ward" or closet is right in my face laying in bed. Has anyond ever cut this, or modified it to take out the closet at least to the headboard trim? Then try to seal it off...so its a short closet. Im just trying to get more ideas of how I can lay on my side and not stare right at the side of the closet, and give me more room if I want to extend an arm or something.
minattz is offline   Reply With Quote
Old 07-13-2018, 06:32 PM   #2
Smart*** comment coming! Put your feet there and put your head where your feet were!
coachjeff1 is offline   Reply With Quote
Old 07-13-2018, 06:40 PM   #3
about that...I'm 6'1 and my feet hang off as is. So that wouldn't work even if I wanted it to.
Old 07-13-2018, 07:57 PM   #4
I’m not 6-1 and I wouldn’t do it either!
Old 07-13-2018, 08:48 PM   #5
XenoRev's Avatar
That's always bothered me too. DW is claustraphobic and resents it but puts up with it.
Oh, and I'm 5 10 and my feet hang off, soo...
2018 Salem 27DBK
2004 Ram Quad 1500
Days past:1996 Coachman Capri-Ruby Ed. 27DS
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3
XenoRev is offline   Reply With Quote
Old 07-13-2018, 09:40 PM   #6
Mr Towed's Avatar
Funny enough we are considering the same thing, kind of. We have a very similar layout except on the starboard side we already have like a night table setup, on the port side we have the full hanging cabinet like you have on both sides. Prior to buying our TT we had rented a 2006 23FB that had the night table on BOTH sides, with outlets on both sides and a very large pass-through storage underneath from outside. We liked that configuration a lot due to its comfort at night, a little more roomy feeling, and somewhere to put your phone down and maybe a tissue box and a glass of water, your glasses... ya know, night table stuff. We might miss the storage a LITTLE bit but we really don't need the hanging storage in particular, and we have another hanging closet in the rear if we did. If we get around to doing this we will certainly post about it and I will try to remember this thread to update about it here, I'd be very interested to see what you come up with. Our trailer is a little older so we're not too worried about "ruining it" by making modifications to the cabinetry. I am a hobbyist woodworker with a pretty well equipped shop so all I really need to do is find the time. My biggest concern is where to safely screw into, and trying to keep things light weight, which i'm not used to having to worry about, so it changes things a little from what I'm used to.
-Jeremy
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Cats: Rhody and Hazy
Mr Towed is offline   Reply With Quote
Old 09-03-2018, 03:32 PM   #7
put a mirror there ..... j/k .... Just got a new unit and have same issue. I'm only 5' 6" and hang off , but thinking I can extend foot end a few more inches might help me.
JumpinJack is offline   Reply With Quote
Old 09-04-2018, 01:18 AM   #8
My TT is configured with nightstands (including drawer) on both sides up to mattress height, 14" open space, then a cabinet up to the ceiling. Maybe you can call your RV manufacturer to see if they make those cabinets that will fit your unit. Or build your own. You can also carefully remove your existing cabinets, remove as much space as you want, add a nightstand top and cabinet bottom and replace. Just some ideas.
Peter is offline   Reply With Quote
Old 09-05-2018, 09:18 AM   #9
Bama PrimeTime's Avatar
Our Surveyor had the same wardrobe closets you have. The problem I had was that the bedroom was open to the main area of the trailer and the noise from the A/C seemed to resonate between those two cabinets making it almost impossible to sleep without a sleep-aid. Our Avenger has the half size (shirt closets) and it is much less of a sound chamber.
John
Ted
Bama PrimeTime is offline   Reply With Quote
Old 12-14-2018, 11:50 PM   #10
We extended our mattress by adding a piece of industrial foam (9”x9”x60”) at the head of the bed. The pillows lay over the foam thus making the mattress “longer”. Industrial foam is denser and firmer than the “craft store” foam.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
bed, cat
