Old 04-02-2015, 09:06 AM   #11
Originally Posted by Knightrider955 View Post
Bought a power Landing gear kit Off ebay brand new for 130 bucks shipped. Came with everything I needed for install including wiring harness and switch. Installed in less than a hour. I couldn't be happier! Just got tired of cranking forever to raise or lower my rig. I always had to switch arms because it was such a workout.
He clearly states "power Landing gear..." nothing about stabilizer jacks or tongue jack.
Old 04-02-2015, 10:32 AM   #12
brer_rabbit10's Avatar
Good for you. You'll certainly enjoy it.
Bill Case
Silverback 35QB4
F350 Diesel prime mover
brer_rabbit10 is offline   Reply With Quote
Old 04-02-2015, 01:28 PM   #13
Ground Control jacks was my favorite and most enjoyed mod. It is great to stand beside the trailer and level it with a remote wireless pad. Can take the tires off the gound if I want to.
EYEMAN is offline   Reply With Quote
Old 04-02-2015, 02:30 PM   #14
Knightrider955's Avatar
Sorry for the confusion. I was referring to the landing gear on my 5th wheel. Not sure a drill would have enough power to run it. Unless my gear just needs a lube job.
2003 Wildwood 28BHSS 5th Wheel
2003 F-350 SRW V-10 3:73 gears
Knightrider955 is offline   Reply With Quote
Old 04-02-2015, 02:37 PM   #15
I believe they were thinking of stablizers.
Old 04-02-2015, 02:39 PM   #16
Most landing gears have a 3 or more to 1 gear box and once you disconnect the motor, a drill SHOULD be able to lift the camper. Glenn Jurczyk gave me a practically new set and it would lock up when it was about 1/2 way extended. Ended up having to take both sides completely apart and put the long screw in a lathe and run a fine toothed bastard file over the entire length of the threads and a knife file in the threads to remove the imperfections. They both run extremely smooth now the complete length of threads. Make sure you lube the entire length of the threads.
Old 04-02-2015, 02:53 PM   #17
B and B's Avatar
Did Glen ever use the zerk to grease the landing gear?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-02-2015, 02:59 PM   #18
Wouldn't have made any difference one way or the other, the threads were lubed as was the nut for about a foot, there were just a lot of burrs/nicks, etc the complete length of the threaded rods. That was the first thing I did when I took it apart was smear grease the complete length of the thread. Ended up having to clean all the grease off and put them in the lathe and do the dual filing.
Old 04-02-2015, 03:15 PM   #19
I have so much to learn. Never heard of that term except on my airplane. It doesn't retract with a drill. Fifth wheelers are a different breed although I may own one some day. That's cool stuff. My landing gear does have zerk fittings though, greased once every year at annual inspection!
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-03-2015, 08:06 AM   #20
Ok so how do I grease these things? Don't think I have zerks. Im sure they have never been greased.
power, modifications
