I ordered the Tornado and after opening the package and inspecting it I am worried about how flimsy it is made. My major concern is the moving spray head and how long it will last. Would it make sense to use all of the Tornado system parts except the rotating spray head and replace that with the No-Flush-Fuss spray head or just replace the entire thing with the Quickie Flush which if I understand it correctly is the exact same thing as the Tornado only it doesn't use the rotating head. I really want to use this type of black tank rinsing system but want to keep it simple and reliable. I've read pros and cons all over the Internet about the Tornado and wondered if any of you have modified the system.
Update: I found this simple mod to the Tornado which should add more stability to the hose connection outside the tank. Still looking for an improvement to the jet inside the tank.
