Old 08-19-2014, 07:22 PM   #1
IchLiebeBier's Avatar
Blinker Repeaters
All,
I searched the forums, but I couldn't find a thread. Maybe I searched the wrong keyword. Anyway...
Has anyone added blinker repeaters to their TT? I was thinking of adding a couple along each side so people can see my signal. I was shocked to realize how far up along the trailer you have to be before you can see the truck blinker.
I figure I can install them along the skirting at the bottom and tap into the blinker wires.
Any good sources for bright repeaters?
Thanks.
IchLiebeBier is offline   Reply With Quote
Old 08-19-2014, 08:31 PM   #2
tmhyer's Avatar
Good question. I'm interested to hear the replies
tmhyer is offline   Reply With Quote
Old 08-19-2014, 08:43 PM   #3
Kaadk's Avatar
Yeah, I was surprised that there wasn't any on the side of the trailer, but then I figured they probably don't make em that way on purpose and never questioned it. If they ignore the one on the back of the trailer, oh well, they'll move when 7000-8000 lbs of wall moves into their way.
Old 08-19-2014, 09:08 PM   #4
jonnys_walkers's Avatar
I have a set of these to install on our trailer.
6" Oval Amber LED Sequential Arrow Turn Signal Light for Truck Trailer Tail Light | LED Oval Lamps | Tail, Brake, Turn, Reverse LED Lights | LED Truck Lights | Super Bright LEDs | Super Bright LEDs
I am mounting these about half way up on the lower skirting.
I mounted these on the back. One set vertical and one set horizontal after a lady in Reno ran into our trailer because she couldn't see I was turning. Hard to miss a trailer that is 13 feet high.
http://www.cerka.ca/comersus7f/store...idProduct=7068
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 08-19-2014, 09:24 PM   #5
Here's a thread:
Clearance lights into turn signals?
2011 Traverse LT, 3.6L, FWD
Old 08-20-2014, 04:13 PM   #6
Here's what just occurred to me:
If I mount some marker lights and tap into the yellow and green wires, the marker lights would work as blinkers.
However, they would also come on when I tap the brakes. This could cause a driver on either side to think I'm turning if I'm coming up to a light (or could cause me to get a ticket).
So, unless someone knows something I don't about the wiring, I think I'm out of luck with doing this easily.
Old 08-20-2014, 06:14 PM   #7
It is easily done. This is what the large trailers have.
Old 08-20-2014, 11:25 PM   #8
jonnys_walkers, IchLeibeBier is looking to mount turn signals half way down the side of the trailer, not on the rear of the trailer. I think the sequential turn signal are cool. IchLeibeBier,it would only look like you were turning if you were tapping the brake numerous times in succession. I doubt you would get ticketed for the side turn signals coming on with the brake lights.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 08-20-2014, 11:56 PM   #9
Back in the 80's we were putting side signal lights on our semi trailers. They were setup like this and the scale in Kamloops gave us tickets after tickets as well as others. Transport trailers have not been set up like this for years now.
Would they go after a travel trailer? Not sure cause ticketing transport units is much easier and there is more money to be made.
Carrier is offline   Reply With Quote
Old 08-21-2014, 12:02 AM   #10
I agree with Grizzly, If you mount this on the side it is either going to point to the front or the back and someone ( most people) are not going to have a clue......Waste of time and money, now on the back, they would work great.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
