Old 08-22-2013, 10:03 PM   #1
TURBS's Avatar
blue streak chemical dispensing system.
At the goshen rally I seen the blue streak chemical guy selling his product and stopped by to listen to his speel about how magical it was.
I listened, got a price and moved on.
Later that night I thought what a great way to also install the geo-method !
I held a meeting with my fellow campers and decided what could go wrong ?
Now before I go any further several of my "friends" also bought a kit.
One of which whom shall remain anonymous we'll call him "blue streak"
Installed his while ms Amy and I were at the SABRE factory tour.
Lets just say his install time took almost took longer than the 2 hour factory tour we took.
Ok back to my theory.
So "my" install took just short of "8" minutes to be exact, "would have taken less time had I not forgot one tool" "bbc"
Anyway I filled the container and finished out the week and the the corresponding weekend with just straight "blue streak" chemical.
By the way it has a nice baby powder smell which is an a+ right from the start.
Ok so we've been home now about a week and the blue streak chemical is down enough that I can start adding my geo-method albeit all liquid now.
I added 2 cups of liquid softner and 2 cups of liquid detergent and mixed the two well with a cup of water.
Then poured that into the blue streak holding tank then filled the toilet bowl about 5 times and emptied.
So over the next few camping trips I'm going check the status of my sewer dumps and see how well if it all this works.
I've instructed the family to use plenty of water with each flush as with every flush the geo method is installed via the blue streak dispenser and I'll see what happens.
I have a 42 gallon black tank and even on a long holiday weekend, we have yet to fill it.
I'll report back soon.
Link.
http://www.bluestreakchem.net/
Turbs
Old 08-22-2013, 10:12 PM   #2
SYE
SYE's Avatar
i purchased on as well from the guy after listening to him, plus he was from Michigan so I got a discount!!! So far mine seems ok, but I have a question about it. Th3e little white clamp on the hose, are you supposed to leave it unclamped always, and clamped for winter?? Mine trickles a bit when I do not have it clamped so I clamped it off.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 43 Nights Camped 2018 27 nights reserved
SYE is offline   Reply With Quote
Old 08-22-2013, 10:15 PM   #3
TURBS's Avatar
Clamp it only when you want to flush straight water.
But in your case if it trickles I'd keep it clamped.
I've thought about the winter situation and I think I'm going to run it dry then add antifreeze through it when I winterize.
Old 08-22-2013, 10:20 PM   #4
SYE
SYE's Avatar
Here are the photos so it did happen!!!
ID:	38451   Click image for larger version
ID:	38452   Click image for larger version
Scott & Vicki
Old 08-22-2013, 10:20 PM   #5
AquaMan's Avatar
I was there during the 2 hour blue streak install and there was some going on. I'm really surprised that a certain "Old Cranky" someone didn't install yours for you while you were on the tour like he was instructed!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 08-22-2013, 10:23 PM   #6
TURBS's Avatar
I did instruct him to but "no results" came of it.
The only thing "he" did was build a porta potty to sell.
Old 08-22-2013, 10:24 PM   #7
TURBS's Avatar
I see your problem sy........
Please use a filter on your next response!
Any guesses?
Old 08-22-2013, 10:54 PM   #8
SYE
SYE's Avatar
I installed the filter but I think it is plugged and not working!!
Scott & Vicki
Old 08-22-2013, 10:56 PM   #9
TURBS's Avatar
Your container is mounted to high.
Gravity be ur problem...
Instructions said to mount lower than the bowl.
I mounted mine almost at the floor.
Old 08-22-2013, 11:07 PM   #10
SYE
SYE's Avatar
OK Thanks I didnt read that one, All I seen was mount it on the wall
Scott & Vicki
