Old 01-26-2015, 02:51 PM   #1
ryand's Avatar
Blue Tote Storage Options
Hi All-
After using our blue tote for a few seasons now at a few campgrounds....got to say I really should have never wasted the money. But since I have it, i need to come up with a better solution to storage of the tank. I have been wanting to come up with a way to get it on the trailer permanently but I am cautious about adding any additional weight to the bumper. I have seen some one here take a harbor freight dolly, remove the wheels and using U bolts secure it to the frame rail and bumper...then strap the tank to the dolly. This may work for me but not ideal.
Really want to try to get it under the trailer behind the rear axle. I happened to catch this link below and thought something similar or a modification to this product would be ideal. Any thoughts?
https://lci1.com/underchassis-tire-carrier
Anyone figure out a way to mount their tank under the trailer? I welcome all ideas!
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 01-26-2015, 03:15 PM   #2
heavynlori's Avatar
We used ratchet straps to mount it under the front cap of our old Dutchmen fifth wheel - it was not enclosed under there like they are now.....
heavynlori is offline   Reply With Quote
Old 01-26-2015, 03:16 PM   #3
heavynlori's Avatar
We also mounted the spare tire under the camper between the front landing gear - we had a Reese hitch installed on the frame in the back that had a platform to haul wood and coolers so we did not want the tire in the way
Old 01-26-2015, 03:25 PM   #4
golfmedik's Avatar
This idea is not under it, but you can get an Over-the-Ladder chair hangar from Camping World and put it on the ladder. Take your tank and sit it in the hangar. You may have to bend it depending on what tank you have. Then take a 10-12 foot ratchet strap and make an X over it and secure it. The hangar is $12 and can be removed easily. Here is a pic of the hangar.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 01-26-2015, 03:36 PM   #5
ryand's Avatar
I would consider this....but I do not have a ladder!
Old 01-26-2015, 06:40 PM   #6
HappyCamper77's Avatar
This is exactly what I plan on doing in the spring. Only I'm using a over the ladder bike rack I have.
Ontario, Canada
2014 Dodge Ram 1500 5.7
2015 Rockwood Ultralite 2905ss
Ontario, Canada
2014 Dodge Ram 1500 5.7L
HappyCamper77 is offline   Reply With Quote
Old 01-27-2015, 03:24 PM   #7
Texas
Blue Tank on Back Bumper
How I solved my storage problem for the blue tank - I purchased a 2 bike rack. I moved the rubber coated bike rods from the top to the bottom and adjusted the width so the rubber coated rods where inside the tires on the blue tank. The upright sides w/ a cross member where left in place and used a strap around the handle of the blue tank and cross member of the bike rack plus some small dia. rope just to make sure it did not go anywhere. I did move the spare tire over and had the modified bike rack and spare tire centered between the tail lights. Rode there for 8 years till I upgraded to a 5th wheel. I now have the spare and a BBQ grille rack on the bumper, so I will have the come up w/ a new plan for the blue tank. Good Luck!!!!
ps: I looked around the internet for a picture of the bike rack I have, but could not find one. Guess I will take a picture of it this evening and post it, although it's no longer mounted to the RV.
830hvacman is offline   Reply With Quote
Old 01-27-2015, 05:37 PM   #8
etothepii's Avatar
Mine is mounted on my bumper with no problems. It is very light.
I got a bumper style bicycle mount at a yard sale very cheap, maybe $5. It comes in two pieces, and with bikes mounted, would rip the bumper right off, I'm sure!
But I cut one piece down and attached it with U-bolts, then strapped the tote to it with bungees. Works out pretty well.
Name:	ImageUploadedByForest River Forums1422401821.724909.jpg
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 01-27-2015, 05:57 PM   #9
We only carry ours when we are going to a park that has no sewer, which is very seldom. It stays at home for 51 out of 52 weeks a year or more.
When we do carry it, it goes on the ladder and attached with bungees.
merrykalia is offline   Reply With Quote
Old 01-27-2015, 05:58 PM   #10
Ret E-9 Anchor-clanker
donanddona's Avatar
Could you send more pics of your bike rack mounted blue tote. I've got a bike rack also but we don't use it. I can fit my tote in the back of the truck but maybe your idea is better.
donanddona is offline   Reply With Quote
storage
