Old 01-20-2014, 04:03 PM   #1
TURBS's Avatar
Boondocking mod for fridge fans.
Of all people my buddy "OC" and I were chatting today and I think I've come up with a new mod for those of us with exterior fridge fans the do some or alot of boondocking.
Currently my fridge fans come on as soon as I turn the fridge on and run continually till the fridge is switched off.
Now we only camp without shore power 2-3 times a year for about four days each using propane.
Why couldn't we splice in the fan power lead into the gas valve power lead so the fans would only run when the fridge is "heating" to cool to save on battery power?
Thoughts?
TURBS
golf cart safety instructor
Old 01-20-2014, 04:30 PM   #2
AquaMan's Avatar
Sounds reasonable to me!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-20-2014, 05:06 PM   #3
Average Joe
MrJoe's Avatar
I clamped a temperature switch to the condenser side tubing and wired it in series with the fan. I also added a lighted power switch. It worked perfect on our trip to Florida. Only heard it cycle with ambient temps around 80. The fridge maintained 32 fridge and zero freezer.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 01-20-2014, 06:56 PM   #4
Professional Curmudgeon
Why not just use a solar powered fan? The only time you want the fan running is when the sun is out anyway and it wouldn't use any battery power at all...
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 01-21-2014, 11:31 PM   #5
trikebubble's Avatar
I installed a 3 speed fan with an on/off switch on the old pop up. I just monitored the internal temp. and adjusted the fan speed as required. Between that and the reflective baffling I put in to help move the heat out, the little fridge would freeze up if need be.
trikebubble is offline   Reply With Quote
Old 01-22-2014, 04:00 AM   #6
fonzie's Avatar
Thoughts?
TURBS
As long as the circuit board can take the extra amps from the fan without failure, then should be OK.
Fonzie
Old 01-22-2014, 06:18 AM   #7
You could get one of these; Solar-powered RV Fridge Vent System - Camco 42165 - Refrigerator Accessories - Camping World
Pipeman is offline   Reply With Quote
Old 01-22-2014, 09:47 AM   #8
BigTJohn's Avatar
Pipeman - those are for rigs with roof mounted vents for the refrig. Turbs has a slide mount unit so vents are in the side of the slide. A small solar panel on the roof and similar fan in the vented space would work quite well.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 01-22-2014, 10:28 AM   #9
BigTJohn,roger, my ooops. Thanks for the heads up.
Old 01-24-2014, 02:29 AM   #10
rsl
I added a attic fan thermostat in the vent tunnel on mine so the fans only come on at a certain temperature. I also installed a lighted rocker switch in line as well as an "on" LED that lights when the fans are running.
2010 Cherokee 295U 36 foot 5th Wheel.
rsl is offline   Reply With Quote
fan, fridge
