Old 04-12-2019, 06:50 PM   #1
Busy winter. Get er done!
Externabond on all roof accessories, Painted skylight, moryde storage box install with light relocation, complete AC matience on both AC units, put vinyl flooring down in storage area, Click image for larger version
ID:	201559Click image for larger version
ID:	201560Click image for larger version
ID:	201563Click image for larger version
ID:	201564 installed new reefer vent cover, Replaced all 120 screws in slide toppers with stainless, recaulked all of RV, Click image for larger version
ID:	201558Click image for larger version
ID:	201556 repaired water damaged outdoor kitchen, installed new water filter housing and summer/winter valve. Click image for larger version
ID:	201554Click image for larger version
ID:	201555Click image for larger version
ID:	201565Click image for larger version
Wow did not realize how much I did till wrote it down.
quick83 is offline   Reply With Quote
Old 04-12-2019, 06:54 PM   #2
Btw I know about the long bubble you see. Itís just a separation where 2 pieces of wood meet and there is a 1/8Ē space and it goes down when cools off. Air is in there. No leak.
Old 04-14-2019, 10:16 AM   #3
Ok I reinspected the area you see raised up. . The wood has come up a little but does not feel softer than any other seam on the roof where 2 boards meet. No leaks that I can see inside. This has looked like this for years but is more noticeable now. The wood moves a little when I push down on it back to the place it should be. I flattened it out with my hand and the raised up area in the edpm goes away. (So Iím hoping itís air!! Iím going to watch to see if comes back up. Can not imagine how water could get in just a 2-3 foot part of seam. Only the AC is what Iím thinking. This elevated area does not extend to the roof edge. I could try to screw it down and cover screws with externabond, I could cut open a slit at the seam and inspect and reseal or just leave it be. Iím not doing anything yet till I get ALOT of opinions. So anyone with roof experience could tell me what they think it would be appreciated. Iím also going to move this to another subject area. Thanks for any advice.
winter
