Old 10-13-2017, 01:35 AM   #1
Cabinet Doors
I want to add a small cabinet door where a cheap screw on panel is now. Will likely only be 18" x 12" or so.
Who is the cheapest online for a custom cabinet door. Thinking I will just get a maple door.
babock is offline   Reply With Quote
Old 10-13-2017, 02:21 AM   #2
Multi-Slacker
I don't think that cheap and custom go together. That said check with what your local Home Depot, Lowes, Menards, etc. If their offerings don't float your boat, try and contact a local woodworking club. Rockler or Woodcraft may be good leads there. If the foregoing all fail, then I think you are going to go true "custom" and a quantity of 1 will be not cheap. Good luck!
Safe Travels
CurtPutnam is offline   Reply With Quote
Old 10-13-2017, 02:23 AM   #3
I have done them on the internet before. Just been awhile. Way cheaper than Lowes, Home Depot...
Old 10-13-2017, 02:44 AM   #4
You might want to check eBay. I needed to add some doors and found almost exactly what I needed. I then had a Sherwin Williams match the stain. They weren't a 100% match but almost 95%. If you can't find what you want on eBay check back every few days.
4x4FF is offline   Reply With Quote
door
