Old 08-18-2014, 11:13 PM   #11
Not all who wanderarelost
I've made and finished cabinets for years and developed quite the knack for matching stains to various previously finished products or making wood components to match different plastic laminate wood grain colors.
My method wasn't very scientific, but it did work. It was just trial and error until you got the right match. The cabinet shop I worked at had 100's of colors of stains collected through out the years. I'd start with an empty can, find the color that matched closest, then i'd slowly add different colors until the blend was just right. I'd mix different brands as long as the base was the same, ie water or oil based stains, etc. The downside to this was, it wasn't a repeatable formula, but you usually ended up with plenty of extra to use down the road if needed. Just make sure you label the can!
Different finishing techniques also help match colors. Sometimes spraying a stain on works better than rubbing. Rubbing it on and leaving it for different periods of times before rubbing off, etc. Gel stains also seem to work great for matching existing products.
MotorCanoe is offline   Reply With Quote
Old 08-22-2014, 09:25 AM   #12
all my "wood" in my 365saqb is just some type of paper that looks like wood and covers the press board that all is made of. At least that how it appears to me. drawers etc. and God does that stuff scratch/chip easy!! been touching up with stain pen.
quick83 is offline   Reply With Quote
