Old 07-25-2013, 10:19 PM   #1
10x
Camp Chef oven adapter to low press. rv line
Does anyone know if there is a adapter to eliminate the regulator on the Camp Chef oven so it can be hooked up to the low pressure outside rv valve?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 07-26-2013, 05:37 PM   #2
10x
Ttt^^^^
2014 XLR 27 HFS
Old 07-26-2013, 07:36 PM   #3
Not sure about the ovens but the camp chef stove are all low pressure and work just fine off the quick connect on the trailers. I just took the factory hose and regulator off and put a change over and male quick connect on my three burner and it works great.
Maybe the ovens are the same???
2012 Lacrosse 318BHS
07 Ford F-350 Super Duty
Hilgy is offline   Reply With Quote
Old 07-26-2013, 08:59 PM   #4
bikendan's Avatar
yep, all the Camp Chef stoves are low pressure and are one of the few options that will work with the quick connect that the optional grills hookup to.
not sure if the oven is the same.
does the oven only work on the 1lb. propane tanks?
Old 07-27-2013, 08:35 PM   #5
10x
Don't know if it will work off the rv line. I have not tried it yet still new in the box. I tried my Coleman stove and it did not work. I was wondering if I will have the same problem with the Campchef oven.
2014 XLR 27 HFS
Old 07-27-2013, 08:44 PM   #6
Campster's Avatar
i have a Camp Chef Pro 90 three burner stove that we use while camping. I purchased the RV connection hose which plugs into the propane quick disconnect connector on our trailer. There is no regulator in line with the hose, it looks like this...
RV connection hose | Camp Chef
Hope this helps..
Campster is offline   Reply With Quote
Old 07-27-2013, 11:27 PM   #7
The camp chief oven runs on a 1 lb disposible bottle with a regulator. But the fitting between the stove and the regulator is threaded looks like a 1/8 npt thread. So you should be able to remove the fitting and adapt it to a hose with a quick connect. Just a thought, I looked at making up a quick connect hose, but so far the darn thing works just fine on the 1 lb bottle. We have used it at least twice a day on each trip and have only gone through 1 bottle. still using the second bottle.
John And Mary
2016 Venom 3311TQ
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (27) 2017 (32) 2018 (34) 2019 (35) 2020 (20) 2021 (5)
Kaboom is offline   Reply With Quote
Old 07-28-2013, 06:14 AM   #8
DDC
DDC's Avatar
ou remove the regulator and replace it with this valve from C/W you will need the hose and quick disconnect ends too.
LP Gas Control Valve with Quick-Connect - Camco 57274 - Propane Hoses and Adapters - Camping World
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-11-2013, 06:15 PM   #9
keller9431's Avatar
I dont have the same grill, but this is what I did to my $100 Walmart grill. The grill I bought had a removeable regulator. I was able to find a hose and fittings to make the hose match my grill and hook up to my quick connect. Been using it all summer and it works great!
keller9431 is offline   Reply With Quote
