Old 07-28-2014, 08:50 PM   #1
can i replace my thermostat
hey guys I have a 2011 Shasta revere 26rls I am curious if I can replace the junky cheap thermostat with a house style thermostat the one in my camper is black and says coleman mach on it its not digital .... thanks in advance guys
sparkync1 is offline   Reply With Quote
Old 07-28-2014, 09:02 PM   #2
VinceU's Avatar
Yes, many have on here. Stay clear of household 24 volt variety, RV's use 12 volt. If possible compare wiring diagrams of existing and which you want to use. Most makers of RV controls offer both Analog and Digital.
Old 07-28-2014, 09:41 PM   #3
Timex's Avatar
Do a search for replacing thermostat and you'll find all the info you'll need.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 07-28-2014, 09:49 PM   #4
Here's what I put in:
2011 Traverse LT, 3.6L, FWD
Old 07-29-2014, 07:25 AM   #5
Make sure you unplug ALL power to trailer first. My buddy fried both ac and furnace boards by not doung so. It was a costly misteake.
Kuba is offline   Reply With Quote
Old 07-29-2014, 07:54 AM   #6
Couple of links for you sparkync1,
Hunter 4299B Digital Thermostat RV Installation
Hunter Thermostat
Old 08-13-2014, 07:10 PM   #7
I also used the Hunter 4299B Digital to replace the old thermostat in my unit. I think the old one was Dometic, it doesn't matter it got replaced. I found the info to do the swap on this forum. You can do a search and find it here somewhere. The swap was really simple and works really well. The old unit would allow the inside temp to change about 8-10 degrees before kicking the A/C in but this new one only allows maybe a 2-3 degree rise. As far as the furnace--it hasn't been cold enough down here to use it yet in four years so far.
Thurman is offline   Reply With Quote
Old 08-14-2014, 05:05 PM   #8
Funny!! I've never used my A/C (except to see if it worked when I bought the trailer). Furnace I use a lot.
Old 08-14-2014, 08:17 PM   #9
Evereddie's Avatar
I had the same thermostat as you do. I put in this one. Coleman Digital Heat/Cool Thermostat (u) 8330-3362 - Programmable Household Thermostats - Amazon.com
Except I found a black one. It was not on Amazon.
BTW, I'm right down the road from you.
Evereddie is offline   Reply With Quote
thermostat
