Old 02-14-2014, 01:34 PM   #1
carpet
anyone ever dyed their carpet ..
credille is offline   Reply With Quote
Old 02-14-2014, 02:17 PM   #2
Fulltime family RVer
As for *camper* carpet- I didn't even know you could dye it. IMO, it's such cheap carpet, that I'd consider replacing it before the expense and work of dyeing it.
Old 02-14-2014, 02:42 PM   #3
Terier's Avatar
I don't know about *camper* carpet but when I lived in an apartment complex the landlord would dye the capet to cover up dirt spots. Several of my neighbors ended up with blue-ish gray socks from walking without shoes on their dyed carpet. This was an ongoing issue for them.
Old 02-14-2014, 04:30 PM   #4
hrlyguy2's Avatar
Im am a flooring installer and also did alot of cleaning.
Dying is one bad idea.For little spots it is ok
Tore out some flooring that was dyed it will fade and get into your padding .
Carpet Is somewhat cheap.Find remnant a to replace might be cheaper
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 02-14-2014, 04:32 PM   #5
Oaklevel's Avatar
DW likes a camper with little to no carpet. So we would never dye it.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 02-14-2014, 04:48 PM   #6
davel1971's Avatar
unfortunately all the slide floors always have carpet, since it helps cover the transition between the floor surfaces. Just stinks you use such low quality carpet, but would you expect any different. Replacing is probably not easy, since furniture is built on top of it and front edges need to be bonded.
David & Lynn
Old 02-14-2014, 04:54 PM   #7
hrlyguy2's Avatar
Binding of edges is really not that hard .and it is very cheap to do
Old 02-14-2014, 04:58 PM   #8
davel1971's Avatar
but unscrewing all the furniture and removing from unit might not be to easy on some floorplans
David & Lynn
Old 02-14-2014, 05:07 PM   #9
hrlyguy2's Avatar
Pretty easy to cut around it then .if you want to do the easy /cheap way
Old 02-17-2014, 11:00 PM   #10
cheese53073's Avatar
You have 4-6 screws per piece of furniture. It's not that hard to remove and do the job right. If you have issues that prevent you from doing this work (many of us do) hire somebody to do it for you. Doing it piece-meal or half way will only leave you disappointed.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
