Old 07-24-2013, 10:23 AM   #1
chorizos338s's Avatar
Cheap Leds
Order a 16ft 5050 led roll for 10$ a pack of pig tails for 5$ from Amazon and was able to do all my lights way cheaper then getting the led bulbs.
ID:	36089   Click image for larger version
2007 georgetown 338se 2006 chevy Duramax 71 chevy K5
chorizos338s is offline   Reply With Quote
Old 07-24-2013, 11:45 AM   #2
Paul & Sheri
pwb01's Avatar
They look good but are they bright enough? I see many lights with the same 5050 description on Amazon. What specifically did you order?
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 07-24-2013, 02:37 PM   #3
I order these SUPERNIGHT (TM) Cool White 5M / 16.4FT 5050 SMD Flexible LED Strip Lights 300 leds or 60led/m LED Light.They look bright ill see later when it gets dark
Old 07-24-2013, 08:18 PM   #4
Leecountry's Avatar
How are they connected into the existing light? Are these the same type as the lights everyone uses for the outside of the camper
Leecountry is offline   Reply With Quote
Old 07-26-2013, 05:47 PM   #5
LKicklight's Avatar
Leds
Probably could run to strips in the same housing and get more light, should not be to much of a problem to get it brighter!
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 07-27-2013, 08:01 AM   #6
Wildwood Danny's Avatar
Good price, looks great. What are lumens?
2006 Silverado 2500HD
2007 Hensley Arrow Hitch
Good Sams Club, Cedar Creek Sams Chapter
RVing is a tough job,BUT someone has to do it!
Wildwood Danny is offline   Reply With Quote
Old 07-30-2013, 05:53 PM   #7
All finish i think the look way better then before i also installed my 5050 water proff multicolor leds under the awning
ID:	36550   Click image for larger version
ID:	36551   Click image for larger version
Old 08-01-2013, 01:59 PM   #8
Definition of lumen:
The lumen (symbol: lm) is the SI derived unit of luminous flux, a measure of the total "amount" of visible light emitted by a source. Luminous flux differs from power (radiant flux) in that luminous flux measurements reflect the varying sensitivity of the human eye to different wavelengths of light, while radiant flux measurements indicate the total power of all electromagnetic waves emitted, independent of the eye's ability to perceive it. A lux is one lumen per square meter.
Flying dutchman is offline   Reply With Quote
Old 08-09-2013, 08:31 PM   #9
Would you please ID the pig tails-Name, number, etc,
Slugger is offline   Reply With Quote
