Old 11-06-2013, 09:19 AM   #1
Cheap Macerator Pump
Convereted used garbage disposal into a Mac.pump! Now the members who were at Goshen could go this route and not have to scurry too buy or (Borrow) additional slinky hose. Run your waste thru a Garden hose. Also you can pump it too your Neighbor? OC you ask for Mod.ideas,heres (1)! Youroo!!
ID:	42343   Click image for larger version
Old 11-06-2013, 09:31 AM   #2
My hose is not too short like some folks I know. I don't need a mac. pump and you still have to use a garden hose and contaminate it.
My hoses don't weight as much either.
Old 11-06-2013, 11:47 AM   #3
silver's Avatar
I was thinking of this for home. Have you actually done it? I was concerned the paper would not go through but tangle. Do you have close up picture of the hose connections?
silver is offline   Reply With Quote
Old 11-06-2013, 10:07 PM   #4
The hose connections are in the Pics.just no hose between the two (2 lug twist on connectors). Short hose determined by outlet height of discharge valve. Paper is NO problem,just like at home use water while in use. Youroo!!
pump
