Added some China eBay LED lights with an autozone 4 selector flat switch to the outside kitchen and also add battery cut off switch. Nice weekend to work on mods.
Nice mods. Where did you get the flat switch. How water resistant is that switch I have been looking for one. But I suck at electricity. Was it hard to install
Mpjduff. It was pretty easy to install. It was 25 bucks at autozone parts store and I do believe you can get water on the selector. I put the main unit behind the access panel where the switch is and ran a wire from there to the fuse panel.
Do you have part number for the switch unit from AutoZone?
in looking at your pics, was the only factory light the one above the sink?
Also - which battery cut-of switch is that one? Perko?
Yes it was the only light in the outside kitchen. And for the battery disconnect it came from eBay. The item number is (160935389669) if you want to see it. Nice switch and easy to install.
